VH41DE UC Sunbird
32 replies to this topic
#1 _GaR_
_GaR_
Posted 16 April 2007 - 05:22 PM
This is exactly as I've posted on GP Forums, my "home" forum.
So, I'm stuffing a VH41DE into my 1980 Holden UC Sunbird.
Here's the hole into which it must fit:
The VH is ****ing wide, so I widened the hole by grinding the lip off each chassis rail:
Here's how it used to be, for the sake of reference:
Between Mettler and me, we've got it this close, after a day and a half:
It just needs the brake booster shoved over a tad, and the rest of that rail ground out, and she'll all be gravy.
Oh, I'll be seam-welding the chassis rails too. Y'know, since I removed all the spot welds when I took my grinder to it.
::edit::
I've read up on Chaotic's LX, and it looks like he gave up on fitting the VH. I reckon it'll be sweet, with a bit of work.
Anyone know what became of that one?
Edited by GaR, 16 April 2007 - 05:32 PM.
#2 RIM-010
RIM-010
    DON'T PANIC
  • 8,075 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 16 April 2007 - 05:52 PM
http://www.gmh-toran...p?showtopic=645
Bart is doing the same, but with an LJ...
Tim
#3 _Azza_
_Azza_
Posted 16 April 2007 - 05:59 PM
Looks good mate. You gonna do anything to the body or paint?
Keep us posted
#4 _GaR_
_GaR_
Posted 16 April 2007 - 06:05 PM
Keep us posted
I'll be leaving the body pretty much standard. I'll only flare it if I have to.
As far as paint goes, I'm dreaming of a different colour scheme every week; we'll see what catches my fancy when I've got the engine, driveline, brakes, suspension, etc sorted.
#5 _Keithy's_UC_
_Keithy's_UC_
Posted 16 April 2007 - 06:16 PM
Well done man. I like seeing something different! What box and diff are you planning on running behind it?
Keith
#6 _GaR_
_GaR_
Posted 16 April 2007 - 06:24 PM
If I leave it n/a I'll probably go for a Toyota W57 or similar. I have no idea what diff to go for though, any suggestions would be more than welcome :D
#7 _Keithy's_UC_
_Keithy's_UC_
Posted 16 April 2007 - 06:26 PM
That all depends on how much power your chasing... I like the supra boxes, good choice there. I'd naturally have to say a 9" for the diff, but there are other options... You could get a Borgwarner from a commodore shortened down and throw that in - they are supposed to be super tough (??)...
Keith
#8 _GaR_
_GaR_
Posted 16 April 2007 - 06:38 PM
I'll be cranking 300+ horse, so I'll need something fairly tough. I'm not all that keen on 9" though, due to the size and weight of them. I've heard some good thing about Hilux diffs.
My flatmate's VK runs a hot 308 and W57, and it spits out Borg Warner diffs with monotonous regularity.
#9 Heath
  • 18,314 posts
Posted 16 April 2007 - 06:50 PM
V8 VN LSD with the right axles is a nice choice ;)
Cool project, keep us updated!
#10 _1uzbt1_
_1uzbt1_
Posted 16 April 2007 - 07:26 PM
awsome project!!A R154 turbo box will hold 500hp easy,not cheap though,and a 4 pinion lsd/spooled 28 spline borgwarner are pretty good too,also can be hard to get and expensive.Some of the bw diffs are 25 spline 2 pinion lsd(falcons etc)and arent as good.
How close are your exhaust ports too the body,will they be easy to do?She looks tight.
Edited by 1uzbt1, 16 April 2007 - 07:27 PM.
#11 _GaR_
_GaR_
Posted 16 April 2007 - 07:44 PM
The exhaust ports are well clear of the chassis; I'll post some photos tomorrow _b
Cheers for the info :D
#12 _Azza_
_Azza_
Posted 16 April 2007 - 07:51 PM
I dont think that donk will worry about the weight of a 9"
#13 _GaR_
_GaR_
Posted 16 April 2007 - 07:54 PM
^ It's more the handling. A 9" is a shitload of unsprung weight to have swinging around back there, especially in a light car like a UC.
#14 Heath
  • 18,314 posts
Posted 16 April 2007 - 08:02 PM
...as I said... V8 VN LSD with the right axles is a nice choice ;)
#15 _Keithy's_UC_
_Keithy's_UC_
Posted 16 April 2007 - 08:56 PM
I'll let you know how my 9" compares to the old salisbury in about 2 weeks time...
Keith
#16 _Chaotic_
_Chaotic_
Posted 16 April 2007 - 09:12 PM
My 9" is gonna be using as many alloy components as possible, adds a fair bit more to the bill but helps to take the weight down.
VH41 is still sitting out in my shed :P
If your going to be going manual i'd be looking towards running an rb25 or 300zx box.
#17 _Keithy's_UC_
_Keithy's_UC_
Posted 16 April 2007 - 10:40 PM
^Keeping it in the family that way too - parts may be easier to interchange...
Keith
#18 LX2DR
LX2DR
  • 1,763 posts
  • Name:Paul
Posted 16 April 2007 - 11:29 PM
Mate i've got a shoe horn you can borrow, dont know if its strong enough for your needs though, thats f*#@ing tight.
Good luck with the project.
#19 _GaR_
_GaR_
Posted 17 April 2007 - 05:30 AM
The Nissan 5-speed boxes are worth more than gold. The Toyota ones are less than a third the price, and don't require much more work. I still need a custom bellhousing, etc anyway >_<
#20 _LX_SS_
_LX_SS_
Posted 17 April 2007 - 06:34 AM
personally i'd pick the toyota r154 over the rb25det box anyday, and i got a rb25det box lol. so much more simple in box design, readily available parts, etc... (for the toyota)
rb boxes start @ $1700 s/h
justjap.com sell the rb25 box new for $3200
still exxy me thinks
#21 _GaR_
_GaR_
Posted 17 April 2007 - 06:54 AM
From what I've seen over the past year, W57s go for sorta $400 - $800, RB20 boxes for about the same, RB25DET/VG30DET boxes are more like $1500-2500.
The W57 is much betterer than the RB20 box, so that'll probably be my pick.
Someone once told me that a T5 won't fit in a UC; can anyone confirm that? And, more to the point, would a T5 handle the jandal?
#22 _1uzbt1_
_1uzbt1_
Posted 17 April 2007 - 11:18 AM
the bennifit of the toyota boxs is they have the removable bellhousing,the nissan boxs ive seen(silvias)dont,what about the rest?Otherwise you will have to make a adaptor plate.
#23 _GaR_
_GaR_
Posted 17 April 2007 - 11:21 AM
^ I'd forgotten about that. A mate of mine has a VH41 and W57 in an R31, so I'll probably get a copy of his bellhousing.
Here are my driver's side exhaust ports, taken from in front of the wheel. I'll get a better photo soon.
#24 dattoman
  • 16,471 posts
Posted 17 April 2007 - 11:22 AM
Forget the manual
The auto is electronic 4 speed
Get it "built" with shift kit and extra clutches (can be done)
You can set up a paddle shift on the column
#25 _GaR_
_GaR_
Posted 17 April 2007 - 11:31 AM
Forget the manual
There are numerous reasons I won't be doing that.
1: I don't have the auto box.
2: I hate automatics.
3: I hate automatics.
4: The factory auto is prone to breaking when abused.
5: I hate automatics.
::edit::
If I stick a VH in my Commodore I'll probably do that, come to think of it.
Edited by GaR, 17 April 2007 - 11:44 AM.
