Door Removal
#1 _onefifty_
Posted 17 April 2007 - 01:28 PM
Could someone please explain how to revome the doors on my LJ?
Ive searched but cant find any thread, sure theres some out there.
150
Posted 17 April 2007 - 02:18 PM
Edited by LC69GTR, 17 April 2007 - 02:24 PM.
#3 _73LJWhiteSL_
Posted 17 April 2007 - 02:41 PM
Steve
Posted 17 April 2007 - 03:13 PM
Oh yeah, that's right, some LJ's had 4 doors.Front doors are pins (as mentioned above), rear doors are simply bolted on.
Steve
#5 _73LJWhiteSL_
Posted 17 April 2007 - 07:57 PM
So do some Range Rovers.Oh yeah, that's right, some LJ's had 4 doors.Front doors are pins (as mentioned above), rear doors are simply bolted on.
Steve
Steve
Posted 17 April 2007 - 08:05 PM
#7 _onefifty_
Posted 19 April 2007 - 08:11 AM
So last nite i tried to pull the doors off... after alot of bashing, pulling and hitting i got nothing!! except for some bent pins :(
Now what? Not even the rears would unbolt!
Any other suggestions? I read the bit about using a oxy torch, I have one, should i heat/cool them and have another go?
Posted 19 April 2007 - 11:38 PM
Weld the doors shut and cut the roof offSo last nite i tried to pull the doors off... after alot of bashing, pulling and hitting i got nothing!! except for some bent pins :(
Seriously, bent pins made me shudder. Soak the hinges and bolts in CRC/WD40 and let them sit. Sounds like oxy on the pins if they are bent though.
Good luck!
#9 _73LJWhiteSL_
Posted 19 April 2007 - 11:47 PM
That should work for the rear door hinges.
Steve
