brakes failing!!
Posted 15 January 2006 - 10:49 PM
the pedAl is going straight to the floor and if i push hard enough the car can stop but not easliy,i noticed if i pump the brakes a lot while driveing they get slightly better and can stop and then go bad again and have to go through the same thing again..they were all fine till last week we had a hot day and a lot of start and stop driveing in traffic then gone bad.is there air in the lines?or is there a leak or maybe the booster/master cylinder?
Posted 16 January 2006 - 01:08 AM
#3 _Yella SLuR_
Posted 16 January 2006 - 09:23 AM
#4 _Oldn64_
Posted 17 January 2006 - 12:23 PM
1. How old is the fluid. if you do nto know wise to bleed and change fluid. water in fluid will make brakes spongey
2. leaks. Common leaks are in rear pistons for drums, rear hose from diff to body, front hoses from caliper to hard line, master into booster. The first thing to check is whether you are loosing fluid.
3. Hoses old and fractured internally. This is what happens usually when the inner hose separates from the outter or fractures. basically what happens is the flexible lines become buldgy and thus do not have enough force to work the calipers.
4. use vise grip gently on teh flexible lines around the car to find whether it is isolated to one corner or the back etc.
5. if running rear drums make sure the shoes are adjusted correctly.
Posted 18 January 2006 - 08:42 PM
i changed the master cylinder and it is a lot better,but doesnt work straight away,pump the pedal 4 times and it stops great,could air or soemthing got in the lines when the cylinder was taken off and replaced?
Posted 18 January 2006 - 08:46 PM
#7 _CHOPPER_
Posted 18 January 2006 - 10:19 PM
#8 _ChiaLX_
Posted 19 January 2006 - 10:02 AM
Posted 19 January 2006 - 11:42 AM
Posted 19 January 2006 - 12:41 PM
Posted 22 February 2006 - 07:02 PM
i have since fitted another 2 master clyinder,both being second hand,,
and neither fixing the brakes,and the and all lines have been bled well.now the pedal pretty much go's straight to the floor,and cant be pumed several times to work.the car does brreak,but not good.and i hit them hard to see what would happen and it did lock up,think front left.so is it the master clyinder that still needs to be replaced again??
thanks
#12 _TORANASS_
Posted 22 February 2006 - 07:33 PM
One thing iv noticed with brakes in my past 15 years of mucking around with cars is "BRAKES HAVE A TENDANCY TO FAIL WHEN NEEDED MOST"
John
Edited by TORANASS, 22 February 2006 - 07:33 PM.
Posted 22 February 2006 - 08:15 PM
Posted 22 February 2006 - 09:05 PM
I'd be looking further down the system myself for other issues
Leaks,lack of adjustment in the rears, swollen hoses, dodgy prop valve
Before I touched the master again
