Adj Trailing Arms
#1 _ChevLX_77_
Posted 19 April 2007 - 11:56 AM
#2 _rorym_
Posted 19 April 2007 - 12:05 PM
#3 _ChevLX_77_
Posted 19 April 2007 - 12:07 PM
Posted 19 April 2007 - 02:00 PM
Another option to consider is replacing the LX upper arm mounts with the upper arm mounts from a UC and use the standard UC arms.
#5 _ChevLX_77_
Posted 19 April 2007 - 03:54 PM
#6 _ChiaLX_
Posted 19 April 2007 - 04:48 PM
The give quite a bit of adjustment to play with. I had to press the bushes in the ends myself though as these were only given in a packet.
I bought em cos i wasnt happy with the angle my nine inch was sitting at, and still want to adjust them a little more on a hoist.
#7 _rorym_
Posted 19 April 2007 - 05:37 PM
#8 _Chamois hatch_
Posted 19 April 2007 - 05:52 PM
time for some research i think, rory you would want to keep your race car as lite as possible as well.
#9 _Bomber Watson_
Posted 19 April 2007 - 06:16 PM
Posted 19 April 2007 - 07:07 PM
I can weight my McDonald Bros arms with super pro bushes tonight. I do not have a standard set of arms to weigh.i wonder how much they weigh, comparing to standard arms, im putting my UC on a diet, but i want it to be (mostly) street legal. any one know the weight of standard arms and the McDonald Bros trailing arms, both uppers and lowers?
The McDonald Bros arms will be heavier than the standard arms, particularly the uppers.
Posted 19 April 2007 - 07:43 PM
They look very similar to the McDonald Bros ones but are much cheaper.
#12 _Chamois hatch_
Posted 19 April 2007 - 07:47 PM
also any ideas on how they compare to boxed trailing arms, ie strength?
#13 _ChevLX_77_
Posted 19 April 2007 - 08:04 PM
I bought some adjustable upper trailing arms and tubular lowers from Rod Tech here in Adelaide.
Have you got a website for rod tech.
Posted 19 April 2007 - 08:41 PM
I would expect a steel tube to be stronger than a plated pressed arm if they both had the same quality steel and weighed the same.
Edited by ls2lxhatch, 19 April 2007 - 08:44 PM.
