Hi,
Can I get some suggestions on wheel alignment settings.
Compromise for a road and track use LC.
Top arm is lowered, car sits about 1" lower than standard XU1 and has long top bolts.
I have forgotton the settings it used to have before the shims went AWOL
I think it was
Camber 2deg negative
Caster 1 1/2deg positive
Toe out 1/16"
Any ideas please? I'm starting with no shims at all to go on.
Greg?
Thanks, John.
LC LJ Wheel alignment settings
_LoneOranger_
, Apr 21 2007 09:36 AM
5 replies to this topic
#1 _LoneOranger_
Posted 21 April 2007 - 09:36 AM
#2 _82911_
Posted 21 April 2007 - 08:32 PM
Howdy John,
1mm toe out.
as much positive caster as your arms will stand!
-ve camber depends on tyre choice mainly. But somewhere in the order of -2 deg would be a compromise start.
Cheers Greg..
1mm toe out.
Cheers Greg..
#3 _LoneOranger_
Posted 21 April 2007 - 10:19 PM
Thanks Greg.
"as much positive caster as your arms will stand!"
You mean my forearms not castor arm right !!!
John.
John.
Posted 21 April 2007 - 10:36 PM
More +castor = heavier steering at low speeds but a more postive feel - don't forget you don't have power steering!!
#5 _82911_
Posted 21 April 2007 - 11:04 PM
John... you have 4 arms???????what's up there buddy!!!!
Yeah mate i was talikin about your "Warwick Farms" not the caster rods...
Cheers Greg..
Cheers Greg..
#6 _LoneOranger_
Posted 21 April 2007 - 11:09 PM
Lots of +ive caster.
That'l bring back some fond memories.
Thanks for the info boys.
John.
John.
