tacho problems!!!!
15 replies to this topic
#1 _levis_
_levis_
Posted 21 April 2007 - 06:50 PM
installed my tacho today its switched to six cylinders but the needle bounces, i've cheked all connections and grounds so next stop is to get a resistor... but the real thing that worries me is the tacho is saying my motor will rev up to 10 grand? any ideas?
#2 TerrA LX
Posted 21 April 2007 - 07:06 PM
Where did you hook the wire up to trigger the tacho from?
#3 _levis_
_levis_
Posted 21 April 2007 - 07:16 PM
negative side of distributer coil??
#4 TerrA LX
Posted 21 April 2007 - 07:32 PM
What distributer is it?
#5 _levis_
_levis_
Posted 21 April 2007 - 07:46 PM
points sorry for all the information i left out i meant to include it!
#6 _ChevLX_77_
_ChevLX_77_
Posted 22 April 2007 - 01:58 AM
Ok is it a standard tacho or aftermarket (Autometer).
#7 rodomo
  • 17,999 posts
Posted 22 April 2007 - 09:12 AM
If it has a switch it shouldn't need a resistor. Has it been laying around in the shed for a while? Flick the switch a few times to "freshen up" the contacts. Re-check all your connections.
#8 _levis_
_levis_
Posted 22 April 2007 - 05:11 PM
the contacts seem fine there is a definate change in revs when i switch from 4 to 6 to 8 it has been in my room for ages.... connections still all seem good a mate said it may be the condensor on the distributer? i also used slightly thicker wire from the end of the tacho wires could this be a problem???? doing my head in!!
#9 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 22 April 2007 - 08:20 PM
There was a thread on this ages ago, can't remember the fix though.
Have a search.
#10 rodomo
  • 17,999 posts
Posted 22 April 2007 - 08:43 PM
Have a search.
I think that was aftermarket electronic though? Try the condenser, H.E.I makes the tacho do funny things just before the module dies sometimes.
#11 _levis_
_levis_
Posted 22 April 2007 - 08:47 PM
will do cheers everyone!
#12 _SS Hatchback_
_SS Hatchback_
Posted 30 April 2007 - 10:32 PM
i had that issue with autometer, but put a variable resistor inline and turned it up until stopped bouncing and all fixed now, I went through thinking it was a bad earth from somewhere but nothing. I am running HEI too.
#13 _devilsadvocate_
_devilsadvocate_
Posted 01 May 2007 - 06:40 PM
What does the tacho misbehave(bounce) on the 4 and 8 cyl positions as well?
#14 _JNR_ATE_
_JNR_ATE_
Posted 05 May 2007 - 08:56 PM
Sorry to steal the thread,
Im having a problem with my SLR cluster tacho, when i first started my engine it was reading good, my autometer was a little more accurate though, then one day it stopped working, Now all of a sudden its working again but about 300Rpm diff to my autometer.
How accurate are the the SLR clusters, all the wiring is new behind the dash so im assuming its not the problem, assumptions are the mother of all @^&$ UPS!
JNR_ATE
#15 _CHOPPER_
_CHOPPER_
Posted 05 May 2007 - 09:21 PM
GMH tachos can be as accurate as any other on the market.
#16 orangeLJ
  • 10,259 posts
Posted 13 May 2007 - 12:54 PM
my LJ GTR cluster tacho has had a slight bounce for ages, only over like 3500, i just live with it, the speedo bounce is the bigger pain in the ass!
