LH Full Suspension Set-Up
9 replies to this topic
#1 _lj chev_
_lj chev_
Posted 23 April 2007 - 08:06 PM
hey guys im in the process of rebuilding and engineering my lh with a rb30et.
i know theres a few links on front end rebuilds and springs and shocks but im getting confused as to what set-up to run.
car will be getting the works so im after opinions and help as what to put in it.
The lh is getting a rb30 turbo motor which is stock atm as im modifying everything else in beforehand but am hoping for 350rwkw later on. trans is a full manual trimatic which will later on be transbraked. diff is 3.45 9 inch.
i want the car to handle nicely on the street and corner well, and also hook up nicely when drag racing. i know sacrifices have to be made for either and i am leaning more towards dragracing setup.
what bushes should be used through out the car?
should i run sway bars/panhard rod for street and remove for draging?
spring and shock set up?
i have adjustable upper control arms, should lowers be adjustable too or boxed...?
what sort of camber/caster should be ran? car will be running commodore wheels
any thoughts and help would be much appreaciated as i want to start buying parts but i thought i would ask the experts first :D
ryan
#2 _SLR Goat_
_SLR Goat_
Posted 24 April 2007 - 07:07 PM
I have always being told the following is a good setup for drag racing correct me if its wrong
Nolathane bushes front and rear
No swaybars(for drag racing anyway)
6 cylinder torana springs front and rear
Koni adjustables on the rear
90/10 shocks up front (get them through peddars)
Boxed rear control arms
Thats the setup i will be using in my LH but it hasnt being on the road yet so i cant give u any info on how it handles I heard the adjustable control arms change your diff pinion angle so they would be improvement in that area for sure anyone else got any ideas or suggestions
#3 _lj chev_
_lj chev_
Posted 01 May 2007 - 07:18 PM
thanks for the help.
i have been told nolathane are to harsh. pedders recomended standard bushes replaced nothing fancy. im not sure what the go is but i know when i drove my car which was standard it felt liek S#!T. what a boat. probly because nothing has been touched in 30 years!
how much where your koni adjustables?
#4 _SLR Goat_
_SLR Goat_
Posted 01 May 2007 - 08:28 PM
I got mine through a mate at mates rate so i dont know the retail price of them. They r only the baseline konis u can only adjust the rebound stiffness u can get more hardcore ones depending on your needs
cheers dennis
#5 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 08 May 2007 - 12:27 PM
you would want to run a swaybar on the back for the strip, the biggest one you can find
#6 _lj chev_
_lj chev_
Posted 08 May 2007 - 01:15 PM
wouldn't it effect squat when launching?
#7 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 10 May 2007 - 11:30 AM
it wont affect the squat as such, it just helps to stop the car twisting over on the launch
#8 _SLR Goat_
_SLR Goat_
Posted 10 May 2007 - 09:04 PM
Forgot to add u might may want to install dome chassis connectors depending on how many ponies your rb30 is pumping out
#9 _lj chev_
_lj chev_
Posted 10 May 2007 - 09:20 PM
what u mean buy dome chassis connecters?
#10 _SLR Goat_
_SLR Goat_
Posted 11 May 2007 - 04:47 PM
Sorry that was a typo meant some chasssis connectors they connect the front and rear rails of the car to stiffen up the body there is a dude in members projects UC_Chev who is doing some atm and has pics posted
cheers dennis
