Electronic Distribitors
#1 _steve253_
Posted 28 April 2007 - 02:38 PM
Posted 28 April 2007 - 02:58 PM
12 volt supply from ignition switch.
Posted 01 May 2007 - 11:17 PM
You will also need the HEI coil to replace your old coil, and the module too.
You may need to change your leads, depends what cap/rotor button you use. If you want to keep your standard cap and leads, simply fit a rotor button from a Ford from memory (someone else will hopefully confirm this).
This is how I'm doing this exact same conversion on my 253 in my hatchback.
#4 _devilsadvocate_
Posted 01 May 2007 - 11:46 PM
The module is fitted to the hei dizzy.......usually considered part of the dizzy.....but worth checking its not missing!You will also need the HEI coil to replace your old coil, and the module too.
Posted 02 May 2007 - 12:51 AM
#6 _steve253_
Posted 02 May 2007 - 07:52 PM
Posted 02 May 2007 - 10:02 PM
Posted 03 May 2007 - 12:14 AM
http://cgi.ebay.com....1QQcmdZViewItem
Edited by rodomo, 03 May 2007 - 12:15 AM.
Posted 03 May 2007 - 03:49 PM
Posted 04 May 2007 - 08:07 AM
There is an electronic dissy on the market currently that is a replica of the Holden/Bosch HEI unit. It uses the same replacement parts etc. & already comes with the small cap & matching rotor. It is probably the one at Auto One that steve253 is referring to. At $249 (including coil) it is a good buy.
When you consider that a 2nd hand one is over 20 years old. Then you have to buy a new coil, cap, rotor & probably a new module, the 2nd hand one is not such a cheap buy. Also there is no warranty on the 2nd hand one.
Dr Terry.
Posted 04 May 2007 - 09:51 AM
Posted 04 May 2007 - 10:39 AM
Yes, they are pretty good. AFAIK the guy who has them made, used to work for Bosch, then left after they closed their Melbourne factory & then set up his own business to make a lot of stuff that Bosch could no longer supply.
If you need one, or need any info, give me a ring at work.
Dr Terry
#13 _The Baron_
Posted 04 May 2007 - 04:25 PM
#14 _rorym_
Posted 04 May 2007 - 08:11 PM
Rotor from XE Falcon V8.Yep, anything from VC right through to VL Commdores I believe (V8 of course, and make sure it's a factory Bosch dizzy). As rodomo said, also WB.
Posted 04 May 2007 - 08:15 PM
#16 _rorym_
Posted 04 May 2007 - 08:20 PM
Posted 04 May 2007 - 08:52 PM
#19 _Lhover_
Posted 05 May 2007 - 05:32 PM
Re the above link - I was thinking of getting one of these kits for my Torry (4.2),has anybody purchased one of these.I know the seller is good as I have purchased from them b4
Chuck.
Posted 24 May 2007 - 12:41 PM
i hear that if you go the small cap option you can't use the hi energy coils that the elec dissys come out with - due to danger of crossfiring.Just get a genuine GMH one, small cap and XE V8 rotor...problem solvered!
True or false?
s
#21 _devilsadvocate_
Posted 24 May 2007 - 01:30 PM
Edited by devilsadvocate, 24 May 2007 - 01:31 PM.
#22 _1uzbt1_
Posted 24 May 2007 - 02:54 PM
Thats the reasoning i heard as well for that massivly oversized cap.i hear that if you go the small cap option you can't use the hi energy coils that the elec dissys come out with - due to danger of crossfiring.
True or false?
s
#23
Posted 24 May 2007 - 03:27 PM
I could be wrong but I seem to remember another thread on this ages ago.
Again I could be wrong but I think XD? XE? V8 had a similar bosch/fairchild ignition distributor that had a small cap from factory and I think that is the rotor button Rory is refering to?
#24 _@milco@_
Posted 24 May 2007 - 04:42 PM
the big cap fits in my lh, it's just a bit hard to do the dizzy lock down nut but other than that it's fine...........
#25 _Monkey_
Posted 24 May 2007 - 06:06 PM
Works here too, i've never had any crossfire issues.Just get a genuine GMH one, small cap and XE V8 rotor...problem solvered! Works on the XU1 V8 ..
