xu1 gearbox shifter
#1 _boynuz_
Posted 07 May 2007 - 09:49 PM
Are they still available repro and has anyone got a picture of one so i know what to look for.
Posted 07 May 2007 - 11:15 PM
The picture below is the correct shifter for the GTR/XU-1 M20 or M21 Aussie 4 speed.
It does not fit the Opel 4 speed that was fitted to the majority of LCs. I understand that from mid 1971 LCs were fitted M20 or M21 Aussie 4 speeds.
Bazza
#3 _boynuz_
Posted 07 May 2007 - 11:56 PM
That shifter looks new do you know were i can buy one or just have to hunt around for second hand.
Posted 08 May 2007 - 12:11 AM
The one in the picture is used. I cleaned it up and had the stick re-chromed. Rare Spares have a repro one - but they are about $400.
Used ones come up on eBay from time to time and go for around $150 - $180.
If you are not worried about originality almost any Aussie 4 speed shifters will fit eg LH or LX. Most other sticks are straight and sometimes hit the handbrake lever. I never found it to be a problem though, I only got this one for originality.
Try posting in the Wanted section of these forums that's where I got mine.
Bazza
#5 _boynuz_
Posted 08 May 2007 - 12:29 AM
I am after a original one if i can't find one for a decent price second hand i will get one from rare spares.
#6 _1973bathxu1_
Posted 09 May 2007 - 09:54 AM
Posted 09 May 2007 - 10:20 AM
Did they still use exactly the same center console and boot as used with the opel shifter with no fouling problems?I understand that from mid 1971 LCs were fitted M20 or M21 Aussie 4 speeds.
Bazza
Posted 09 May 2007 - 12:14 PM
As I recall the LC (Opel) console has an offset hole and a different boot and trim. I think you can convert an LJ to LC but not vice versa, because of the offset hole goes into the trim area.
Bazza
Posted 10 May 2007 - 10:42 AM
I just did some browsing, apparently the LC's that came with the aussie box were the 179 model. They also came with an LJ console with a 4 speed gear knob.
can anyone confirm?
Posted 10 May 2007 - 11:18 AM
Hi smeeryeah,
can anyone confirm?
I think you mean 173
Re Console:
LC owners might argue that LJs came out with late model LC consoles
Bazza
Posted 10 May 2007 - 11:47 AM
Thanks bazza!
