radiator
71xu1
, May 09 2007 12:55 PM
10 replies to this topic
Posted 09 May 2007 - 12:55 PM
Does any one know or have any pics of the correct radiator shroud for an lc xu1. I think thet are different from the lj xu1?. Is the lina mint xu1 featured in the last issue of amc may be the corrrect one perhaps?
Posted 09 May 2007 - 01:22 PM
Hi 71xu1
All the 6 cylinder LC and LJ Toranas had the same flat fan guard as pictured in AMC. The important thing however is that the correct part number is stamped on the guard. Someone with an LC parts manual should be able to post the correct number.
I have seen man yLJ XU-1s with a "period correct" fan guard but incorrect part number.
Bazza
Bazza
Posted 09 May 2007 - 01:52 PM
Is it bad that I don't have one on my 6cyl 4 door LC?
Posted 09 May 2007 - 02:04 PM
Hi Guys.Is it bad that I don't have one on my 6cyl 4 door LC?
Technically it is bad, AFAIK it's a finger guard, to stop peoples' fingers getting cut up by the rotating fan blades, if you're turning the radiator cap with the motor running.
Dr Terry.
#5 _LC870_
Posted 09 May 2007 - 02:15 PM
Hi to all .
The correct number for the Fan guard for the radiator on the
LC GTR XU-1 is 2816453.
I hope this helps you out with youe queries .
#7 _1uzbt1_
Posted 09 May 2007 - 03:55 PM
that appears to be out of a EH Holden not a torana,core date is feb o6. Looks stuffed too,core leak on right hand side,ya can see the stain
Posted 09 May 2007 - 05:04 PM
too wide for EH
funny mounting brackets as well
#9 _1uzbt1_
Posted 09 May 2007 - 05:42 PM
definatley original EH as my core book tells me anyway from his part number given in the ad.
Posted 09 May 2007 - 05:56 PM
Hi Guys.
That radiator is unique to the EH 179. The EH 149 is narrower & similar to an EJ radiator.
Dr Terry.
Dr Terry.
#11 _1uzbt1_
Posted 09 May 2007 - 06:55 PM
and their a prick to work on!!!!
