17" mags on LC, Clearance problem
superfly_GTR
, May 09 2007 05:29 PM
11 replies to this topic
Posted 09 May 2007 - 05:29 PM
Hey everyone,
I picked up a set of 17" mag wheels the other day to run slicks on my LC for track days and they fit perfectly except for the fact that on full lock they hit the swaybar/radius rod mount.
I was just wondering if anybody had come across this problem before and/or a way to rectify this problem, ie: is it possable to fit a bump stop for the steering or reduce the steering arm travle?
Cheers Matt
Cheers Matt
#2 _JBird_
Posted 09 May 2007 - 05:59 PM
What offset?
How wide are the wheels.
Posted 09 May 2007 - 06:45 PM
Not sure on offset (they came off a volvo) 7.5" wide, they fit fine I just want to stop them hitting the swaybar.
Cheers Matt
Cheers Matt
#4 _dickiep_
Posted 09 May 2007 - 08:54 PM
are these factory rims? got any pics? 7.5 all round?
Posted 11 May 2007 - 06:40 PM
Not factory rims aftermarket british made, I bought them off ebay last week listed for early holden, and yeah 7.5" all round but what I want to know is can i do something to the front end or steering to remedy this problem?
Cheers Matt
Cheers Matt
#6 _JBird_
Posted 12 May 2007 - 12:08 AM
Are you running XU-1 Style hubs/discs/brakes?
It wouldnt be safe to run spacers.
Posted 12 May 2007 - 12:32 PM
Yes XU1 thikness brake rotors, if I used spacers wide enough to fix the problem I think the wheels would hang outside the guards and I would need to fit longer studs.
What about adjustment in the steering?
Cheers Matt
Cheers Matt
Posted 12 May 2007 - 01:45 PM
If it is only hitting on the Swaybar mounts I'd put a different type of swaybar on - those factory style LC swaybars are one of the most useless arrangements I have seen anyway.
If it is hitting something more vital in your suspension, perhaps a hoppers brake kit will help - they move the wheels out about 8mm I believe and you get the brakes to fill the 17's at the same time.
#9 _JBird_
Posted 12 May 2007 - 02:30 PM
It moves it out 18mm or 24mm. So the offset will be wildly different to anything "oldschool" (19-25p wheels).
Posted 12 May 2007 - 02:45 PM
JBird, Is that ^ just for the LC/LJ hoppers kits?
M@
M@
#11 _JBird_
Posted 12 May 2007 - 03:18 PM
I believe so.
LH-LX I think can still use lower offset wheels or bigger than 15" (modern) rims to clear the control arms - which I think is the only problem with using modern wheels on those.
Posted 12 May 2007 - 07:34 PM
thanks for all your help and options guys but as im only planning to use them every now and then for track days all im wanting to do is stop the wheels from turning so far as a reduced turning circle is not an issue.
So is there any way of limiting the turning circle?
Cheers Matt
Cheers Matt
