Chassis Kit?
#26 _youngy_11_
Posted 27 May 2007 - 02:20 PM
Much better doing it yourself or getting it done properly by a auto fab place.
The guy that fabed mine said he has cars doing 4ft wheel stands 1000Hp with what i Had done and never any problems, also improves handling quite a bit 2.
cheers youngy
#27
Posted 27 May 2007 - 07:52 PM
From what I can see the mod above connects the lower trailing arm mount to the chassis rail which effectively reinforces the trailing arm mount. I can see that this would increase the bending strength of the vehicle but I can not see how it would increase the torsional strength.
The CRS LH-LX kit runs from the lower trailing arm, bolts to the chassis rail using the gearbox crossmember bolts, then bolts to the K-frame mount then about 300 mm up the chassis rail. It is then cross braced by the stronger gearbox crossmember (not shown). The CRS kit does not intrude into the rear seat footwell.
#28 _youngy_11_
Posted 27 May 2007 - 08:30 PM
So bending stress is like bending the vehicle about the centre?
and
torsional stress is like twisting the chassi??
#29 _JBird_
Posted 27 May 2007 - 11:56 PM
How heavy is the CRS kit anyway?
From memory it was $825...
#30 _rorym_
Posted 28 May 2007 - 12:05 AM
#31 _JBird_
Posted 28 May 2007 - 12:13 AM
Shane...Hit the treadmill/Go alloy headsMax 20 kgs.
#32 _JBird_
Posted 28 May 2007 - 01:22 AM
How much would you pay for one (I know there are some on Ebay).
Should I bolt/Weld it in. And the rear connection points seem to stop on the parcel shelf...is that strong enough?
#33
Posted 28 May 2007 - 06:08 PM
Im trying to buying the front end kit seperatly but CRS wont give me a straight answer if i can or cant via email and i refuse to call them. (i should call i know)
Adam
#34 _rorym_
Posted 28 May 2007 - 07:21 PM
Adam..If you mean by the front end kit...the bars that weld into the front arms..I have a set you can have, I had genuine XU1 front arms so didnt use them.The Lj chassis kit is $930 which includes the front end kit too.
Adam
Rory
#35 _rorym_
Posted 28 May 2007 - 07:24 PM
I have welded my cage in the L34..now I have to drill bolts in it because thats what Qld Trans wants to see..go figger. James anything is a help...just do it..Also is it worth putting a 4 Point Steel/Alloy roll cage into my LJ?
#36 _onefifty_
Posted 28 May 2007 - 08:23 PM
What is involved in installing a kit? is there a insruction set someone could post please?
#37 _JBird_
Posted 28 May 2007 - 11:04 PM
On the note about the lower control arm "brace" (not the metal rods the good ones Rory is always raving about) - where can you get them? I've searched on Ebay to no avail, does the "guy" still make them or what?
#38
Posted 29 May 2007 - 11:25 PM
#39 _LJ355_
Posted 30 May 2007 - 07:47 AM
#40 _rorym_
Posted 30 May 2007 - 01:33 PM
Yeah me too but you need to know we have taken a 60% increase hit in the building industry on steel over the last 18 months..China is taking it all..not making excuses for them but the numbers sort of fit.$930 for the chassis kit ? i paid $550 18 months ago
#41 _rorym_
#42 _JBird_
Posted 30 May 2007 - 11:15 PM
#43 _JBird_
Posted 14 June 2007 - 02:22 PM
#44 _rorym_
#45
Posted 28 June 2007 - 07:06 AM
#46 _dags383_
Posted 28 June 2007 - 10:05 AM
I had not one ounce of trouble fitting my kit but then i bought it s/hand from Adam when he was over east so it had been run in per say.
Cheers,
#47 _big_als_army_
Posted 30 June 2007 - 01:37 AM
Mine, hehe. I've already got the XU-1 reinforced lower control arms in mine but I wanted the crossmember to radius arm strengthening brackets as they crack badly on the radius arm at that junction. The only other piece missing from that front end kit is the plate that you weld over the bottom of the crossmember. I bought my body bracing and front end strengthening kit for $600 about 3.5 years ago. At the time I spoke to Rod Hadfield and he said the crossmember plate doesn't do anything at all strength wise, its purely cosmetic to cover up any marks from when the car has been jacked up and left impressions in the bottom of the crossmember in the past. I still have the delivery docket for the kit and all up it weighs 25kgs.More bits.
http://cgi.ebay.com....1QQcmdZViewItem
#48 _rorym_
Posted 30 June 2007 - 07:56 AM
12mm.what size is the rod use on the lower control arms? I sold my gtr which had my welded up control arms.
#49 _big_als_army_
Posted 05 July 2007 - 10:15 PM
Yep, mine too. Was anyone from here bidding on it in the end? Jacked up the price on me. Its still cheaper than new from CRS and has some extras included too.There is another set of CRS chassis rails on Ebay at the moment.
