can has a 208 with 186 yt head running 350 holley
recently (last week) it started to run rough. feels like it running cold, ie on take off almost dies until i give it more revs than normal and is still slugish. also when driving at a constant speed it jumps (misses?) occassionally. had a recent servie, with new hoses and fuel filter etc. no other problems to date. any ideas?
Running Rough
_dickiep_
, May 23 2007 08:48 PM
4 replies to this topic
#1 _dickiep_
Posted 23 May 2007 - 08:48 PM
Posted 23 May 2007 - 08:53 PM
Check for air leaks and check timing.
#3 _dickiep_
Posted 23 May 2007 - 08:57 PM
ok, air leaks in fuel lines? ill get the timing gun out tomorrow
Posted 23 May 2007 - 09:04 PM
Make sure the manifold bolts & nuts are tight, particularly the back one - they come loose and suck air making the engine run rough.
#5 _Bomber Watson_
Posted 23 May 2007 - 09:29 PM
also check the plugs for fouling and the power valve in the carbie. they both tend to play up...
