Max Horespower for -
_hux454_
Posted 19 January 2006 - 07:22 PM
Got my LX SLR 5000 dynoed for the first time yesterday since buying her.
Had no receipts for the motor work done to it but the owner i bought it off (only had it for 12 months) told me when he bought the car the motor was only a couple of thousand kilometers old (now done approx. 4,000kms) & that Ian Tate in Melboure had built it.
It's very street driveable pulls like a 14 year old & is excellant on fuel. What i do know is it has L34 type heads, some sort of work done to the standard carby, elec ignition, roller rockers, alluminiun flywheel, cam, blue printed & balanced.
Anyway got it dynoed & it was doing 330 fwhp. Bloke who dynoed it said that whoever built the motor had done a top notch job & he told me not do do anything to it as it was running sweet. I asked him roughly how much a motor like that would be worth. He said approximately without pulling the motor done to see - $10,000. I thought no shit and then asked him how much horsepower a 308 can produce without supercherger/stroking etc. He said around 350 fwhp depending on diff types/gearboxes etc as they are a relatively small cubic inch motor & there is only so much you can do to them (without doing the above). I was wondering if this was true.
Any info would be great.
Glenn
Posted 19 January 2006 - 07:36 PM
On the other hand, 330fwhp is still a very powerful 308 and anything much over 400 is a just asking for you to spend far more on the rest of your driveline (diff, transmission, cooling and rear rubber - possibly even mini-tubbing). Consider yourself very lucky; a lot of people would kill for a car like that.
Posted 19 January 2006 - 09:00 PM
Posted 19 January 2006 - 09:16 PM
Any N/A V8 engine making 1.2-1.3Hp per cubic inch is a VERY well built engine.
308s suffer a MAJOR restriction in the design of their heads, and the only way to overcome this is to go to the late style VN heads ( thats why its such a popular conversion). THey flow SO much better its phenominal and even though yours are the better type of early head.. theyre still early heads.
I think you should be happy with your result from what i read above, but 308s can now be made into killer engines with the new gear thats around for them.
Cheers!
_TORANASS_
Posted 20 January 2006 - 06:56 AM
308s have mega potential now, gone are the days were you needed to adopt a SBC to go fast..
John
Posted 20 January 2006 - 12:02 PM
_77LX253_
Posted 21 January 2006 - 08:32 AM
Posted 21 January 2006 - 12:48 PM
_Yella SLuR_
Posted 21 January 2006 - 12:56 PM
Posted 21 January 2006 - 02:44 PM
_TORANASS_
Posted 21 January 2006 - 04:40 PM
Dont no why you would do it to a 253 tho..
John
Posted 23 January 2006 - 09:46 PM
_82911_
Posted 24 January 2006 - 07:02 AM
Problem with a 253 is going to be a very small swept volume pulling on a fairly large intake port. This kills air speed, and airspeed is where you get your torque from!
For a 253, stick with mildly ported red heads, aim for 10:1 comp cam around 240@50 and about 520lift @the valve. cleaned up standard 4 barrel intake or edelbrock performer, nice pipes with at least 1 1/2 primaries. For a carb, i'd say a 456 vac sec or 465 mech would do the job well.
A tip... 253's like a bit more ignition lead than a 308.... so start around 34-36degrees total advance.
That motor if assembled carefully should be good for around 280Hp@fly. Will pull like a train from 3000- 6000 and will leave you with change from $2500.
Cheers Greg..
_Yella SLuR_
Posted 24 January 2006 - 07:34 AM
Posted 24 January 2006 - 08:43 AM
Edited by REDA9X, 24 January 2006 - 08:43 AM.
Posted 24 January 2006 - 01:28 PM
Posted 24 January 2006 - 06:41 PM
also, is it possible to put one of the larger cranks for a 308 (like the 355 stroker item) into the 253 block??? i know the main journals are different but this can be line bored out....i'm thinking 253 block with largish internals...problem is i would have a motor with a small bore and very long stroke...not so great i suppose.
Edited by lc boi, 24 January 2006 - 06:43 PM.
Posted 24 January 2006 - 06:52 PM
Dont be too worried about the HP output of the engine..
Its the torque curve you REALLY want graphed. Try and get the curve as fat and stead as you can and you KNWO youve got a good engine. It'll pull like a train even if you loose a little up high where the HP numbers count.
(Hp is a function of torque over time and so one will affect the other but ive seen high HP machines with little or no torque, and on the street.. torque is what counts!)
and OH... the 253 greg's talking about is about what i'd like to build for the SLR
_Torana482HP_
Posted 28 January 2006 - 05:36 PM
ill give more detail of the engine specs if anyones interested. special billit camshaft produces power from 2000 - 7500 rpm. now who said you couldnt get a 253 cooking.
