LX with drop tank rear springs
13 replies to this topic
#1 _lcgtr_
_lcgtr_
Posted 28 May 2007 - 10:25 AM
The rear springs shouldnt change if you fit a 120L drop tank should they? Not if the tank is made correctly
#2 ls2lxhatch
  • 5,332 posts
Posted 28 May 2007 - 10:44 AM
The spring design will not change. You may find that you want a different spring height or rate due to the extra weight ( approximately 60kg more than standard full tank ).
If you fill the standard tank and get a friend to sit in the boot you would get a rough idea of the ride height.
#3 _youngy_11_
_youngy_11_
Posted 28 May 2007 - 11:22 AM
Slightly off topic,
But would a 120litre aluminum drop tank be lighter than the original steel ones??
With no fuel in them???
cheers youngy
#4 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 28 May 2007 - 12:18 PM
No.
I have both on the floor at the moment, the drop tank is distinctly heavier.
Welby
#5 dattoman
  • 16,471 posts
Posted 28 May 2007 - 12:24 PM
Put one in a car
#6 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 28 May 2007 - 12:30 PM
need car
#7 _youngy_11_
_youngy_11_
Posted 29 May 2007 - 02:55 PM
Yeah,
aww well can't beat the looks.
Im ordering one from Brown Davis Soon.
So distinctly heavier???
Double the weight??
#8 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 29 May 2007 - 03:48 PM
Not double the weight, but given your about to double the capacity of the fuel and therefore the weight therein, i wouldn't be fussed about the weight of the tank.
If your getting a BD, you will be happy.
Welby
#9 _rorym_
Posted 29 May 2007 - 06:09 PM
need car
Get up him Welby!! :gun: :furious:
#10 _youngy_11_
_youngy_11_
Posted 29 May 2007 - 08:02 PM
Hehe yeah, should be.
#11 ls2lxhatch
  • 5,332 posts
Posted 29 May 2007 - 09:00 PM
My Brown Davis 120 lt tank with swirl pot and 1/2" pickup weighs 12.8 kg.
#12 _youngy_11_
_youngy_11_
Posted 03 June 2007 - 06:35 PM
Is that all mmm surprising.
Thanks alot.
Im getting the same tank,
Works well obviously??
Cheeres youngy
#13 ls2lxhatch
  • 5,332 posts
Posted 03 June 2007 - 08:33 PM
Youngy,
If you are running EFI then the Brown Davis 1/2" pickup and swirl pot is not required. I intend to modify my Brown Davis tank considerably to suit an EFI fuel system.
What plans do you have for the fuel system?
#14 _youngy_11_
_youngy_11_
Posted 03 June 2007 - 08:54 PM
Ok,
Im not 100% as dad rang up last week and I haven't really talked to him in depth about it.
He said Brown Davis recommended the swirl pot and 1/2"pick up from memory.
Anyway what are ur suggestions/ intentions with the EFI set up.
Also do you have any pics or ur tank on the car just to see how low it is.
Edited by youngy_11, 03 June 2007 - 08:58 PM.
