My Monster truck
14 replies to this topic
#1 _kaz from adelaide_
_kaz from adelaide_
Posted 30 May 2007 - 05:44 PM
What the hell has happened.
Springs were V8, front end changed to UC. I was told it would drop once all panels, radiator etc went back in. WELL she is stayin on tippee toes. But I wont have a scraping issue.
I am seriously thinking of gettin some nobbly tyres and go hill climbing.
On top of that, the air cleaner hits the bonnet :fool:
front
rear
#2 GML-31
Posted 30 May 2007 - 06:10 PM
I would say they are standard height thats why...
#3 _noslx_
_noslx_
Posted 30 May 2007 - 06:24 PM
well kaz get the angle grinder out cut the springs and cut a hole in the bonnet :spoton: probs fixed
#4 _kaz from adelaide_
_kaz from adelaide_
Posted 30 May 2007 - 06:39 PM
yeah well I suppose I am used to seeing her with lowered 6cyl ones.
Is that seriously how high they sit on standard springs ?
Is cutting springs Ok ?
How much and which end ?
XXKAZXX
#5 _Bomber Watson_
Posted 30 May 2007 - 08:28 PM
dont cut the springs kaz, lowered ones are cheap.
also, if there brand new, try driving with them for a little while. springs sag rather quickly when there new. not that much though.
#6 ls2lxhatch
  • 5,332 posts
Posted 30 May 2007 - 10:15 PM
The front suspension will not drop until you roll the car forward or backward as the tyres need to move sideways when the suspension lowers.
What sort of air cleaner do you have?
Edited by ls2lxhatch, 30 May 2007 - 10:15 PM.
#7 limo
limo
  • 2,672 posts
Posted 30 May 2007 - 10:26 PM
that's too high for standard and did you use right engine mounts or have you got different inlet manifold on it?
I have one sitting at depot in hahndorf if you want to campare/measure was 6cyl converted to 8 with 4spd
#8 _kaz from adelaide_
_kaz from adelaide_
Posted 31 May 2007 - 05:47 AM
# standard dinner plate air cleaner.
# torrie engine mounts
# used springs
The motor sits very low in the engine bay, lots of clearance below heater box.
Gone from 6cyl column auto, to 8cyl column auto.
XXKAZXX
#9 _Holdenmad_
_Holdenmad_
Posted 31 May 2007 - 10:47 AM
Check that the springs are sitting in the retainers in the cross member.
My LH sat pretty high on one side and it was just that the spring was not sitting completely in the correct place in the cross member.
Otherwise, you may have been sold the wrong springs.
As bomber says, don't cut them, buy lower ones. I beleive that cut springs are a defectable offence here in SA, if not the whole country.
Edited by Holdenmad, 31 May 2007 - 10:49 AM.
#10 ls2lxhatch
  • 5,332 posts
Posted 31 May 2007 - 08:03 PM
There are several styles of bottom plate for the typical aftermarket air cleaners. You will find some styles lower the air cleaner by about an inch when compared with others. It is difficult to explain, hopefully someone will post a picture.
#11 TerrA LX
Posted 31 May 2007 - 08:51 PM
If you order new springs make sure you give the measurement you want from the top of the wheel arch to the center of the wheel to avoid dissapointment.
#12 _kaz from adelaide_
_kaz from adelaide_
Posted 01 June 2007 - 09:47 AM
ta muchly guys
XXKAZXX
#13 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 01 June 2007 - 01:33 PM
easy fix kaz , put a big block under the hood and some bricks in the boot !
#14 _HatchmanSS76_
_HatchmanSS76_
Posted 04 June 2007 - 11:48 PM
Sounds like you have an air cleaner where the base plate is flat and level with the top of your carby.
You need one where the base plate drapes over your carby. This will allow you to run large filters without problems. My old 4door had a massive thick/high air filter with no hole in the bonet and cleared no probs.
I have attached a photo of the engine in the old hatch to show how the carby is hardly visable with the drape over base plate.
#15 _Toranamuk_
_Toranamuk_
Posted 05 June 2007 - 12:42 AM
Wait till it gets tuned, I'll look at it then.
I have ways & means of making things fit !!!!!! :tease:
