Does anyone now if the xu1 rat trap was any different then say a standard Lc or Lj.
I have found my original rat trap of my 71 bathurst and it looks to be different then a standard one's. The v section looks thicker and a little wider will post pics soon.
xu1 rat trap any different
_boynuz_
, May 30 2007 09:42 PM
4 replies to this topic
#1 _boynuz_
Posted 30 May 2007 - 09:42 PM
#2 _rorym_
Posted 30 May 2007 - 09:44 PM
There was a mod in 1971 as an ugrade..thicker arm/a plate and pin area..you have got that one..they are all the same otherwise.
Edited by rorym, 30 May 2007 - 09:44 PM.
#3 _boynuz_
Posted 30 May 2007 - 09:48 PM
Hi Rorym
Mine is exactly as you describe so anything after 71 is the thicker type.
#4 _rorym_
Posted 30 May 2007 - 10:35 PM
No..it was a dealer refit if it broke..very sneaky!..and available over the counter as a part
Posted 31 May 2007 - 03:23 PM
Hi Rorym,the hg holdens 3 on the tree had the same rat traps as the toranas,the part that holds the cable from the clutch pedal,is double the thickness than a ordinary LC or LJ,and its more stronger than the torana part,cheers.
