Put my lc on stands today as the weekend weather is goin to be shite so im going to clean up the under carrige a bit, Now me and my mate have argued over where is the best place
\_/ this is what the cradle of the stand looks like.
Where do you all put them
lc lj on car stands
mranarot
, Jun 15 2007 10:07 PM
4 replies to this topic
Posted 15 June 2007 - 10:07 PM
Posted 15 June 2007 - 10:36 PM
Rear ones sit under axle tubes, for the front I use a small piece of 10mm steel plate in each cradle (sits proud of the cradle 'wings' ) and then locate them under the crossmember (this is for an LX).
Posted 15 June 2007 - 10:47 PM
Hi
If you have 4 stands and you want the suspension stations to hand down on all 4 corners - place the stands in the same positions indicated in the owner's handbook. If you intend to clean underneath you will probably want all the clearance that you can get.
Bazza
Bazza
#4 _markm_
Posted 15 June 2007 - 11:07 PM
Hi,
Go with Thrillseeker idea for the rear, the front i would place along the chasis rail towards the front.
#5 _73LJWhiteSL_
Posted 16 June 2007 - 11:13 AM
Ditto, except i use a piece of wood on the stands under the front, on the LJ.Rear ones sit under axle tubes, for the front I use a small piece of 10mm steel plate in each cradle (sits proud of the cradle 'wings' ) and then locate them under the crossmember (this is for an LX).
Steve
