newbie need advive
#1 _lachlanthegreat_
Posted 18 June 2007 - 08:55 PM
#2 _Monkey_
Posted 18 June 2007 - 09:02 PM
#3 _jap-xu1_
Posted 18 June 2007 - 09:14 PM
the best option in my books
Posted 18 June 2007 - 09:57 PM
depends on what your looking to do.
if you are looking for a streeter with good performance, sounds tuff and easy to build, buy and install. go the red6.
problem with a v8 is they dont like to corner a whole lot!!
and with a nissan 6, well just my opinion, but there would be hassles with getting it engineered and so on, well not problems, but more then a red 6 if you know what i mean.
and you cant kill a red 6! haha. well you can.but takes a bit.
#5 _Feigz_
Posted 18 June 2007 - 11:19 PM
#6 _JBird_
Posted 19 June 2007 - 01:02 PM
Where as if your going to do another engine you will need to upgrade your brakes among other things just to get it reregistered. If I would have one LJ and one LC, had my way, LC SR20DET and LJ EFi 355. One for driving and one for cruising =p
Edited by JBird, 19 June 2007 - 01:02 PM.
Posted 19 June 2007 - 01:14 PM
#8 _gmhgtr_
Posted 19 June 2007 - 11:08 PM
personally either a 186, or more a 202 with a 186 head if you like or for reliability go with a newer EFI engine, less hassles in away if its done properly, so no hassles arise, but everything has its ups and downs and looks pretty different, i dunno about some storys that a V8 is to "front heavy" in a lil LC or LJ, but yeah looks the part though,
either way be different and go EFI jap or V6 or even 8, or stick to carby!
gmhgtr
#9 _willo_
Posted 19 June 2007 - 11:26 PM
#10 _sunburst_metalic_
Posted 22 June 2007 - 09:23 AM
Sound advice, even a 202 Blue motor with carb and a 5 speed would be ausome. I have a friend that did the Blue to Black motor swap for the EFI and extra preformance was not noticable it was smoother he said (in a nut shell not impressed). rgds Sunburstmate don't go too wild with it if it's gunna be a daily driver.... a vk efi 3.3 or a commodore v6 would be ya best bet...and keep the engine stock in both cases she will go well and be reliable. my 2c worth anyway!
Posted 22 June 2007 - 11:16 AM
Posted 22 June 2007 - 04:49 PM
what did you do for exhaust? I had trouble with standard set up fitting and went to extractors in an LJI started with a VH 3.3L Blue, was a great update. Easy to fit. Nothing to complex. Pull out bolt in. and electric dizzy so only thing you have to change is the 6 volt start wire to 12 volt.
Posted 23 June 2007 - 02:46 PM
Posted 23 June 2007 - 07:46 PM
Whoops forgot about that. Yeah you need to get a set of extractors cause they have different headswhat did you do for exhaust? I had trouble with standard set up fitting and went to extractors in an LJI started with a VH 3.3L Blue, was a great update. Easy to fit. Nothing to complex. Pull out bolt in. and electric dizzy so only thing you have to change is the 6 volt start wire to 12 volt.
#15 _JBird_
Posted 23 June 2007 - 08:10 PM
I need a set, doing the conversion (black motor) on mine soon!
Posted 24 June 2007 - 01:43 AM
