Posted 19 June 2007 - 11:57 PM
Ofcourse you can not find anything for aussie U.S. stuff in the cattle dogs but from what i know ACCEL STREET BILLET PERFORMANCE ELECTRONIC BREAKERLESS DISTRIBUTOR
� Ready to run, self-contained electronic breakerless design
� ACCEL's new 12-volt breakerless 6.5 Amps dwell control module
� CNC-machined billet 6061-T6 aircraft grade aluminum housing
� Centerless ground steel shaft with upper and lower Oil Lite bushings
� Easy access top mount fully adjustable and lockable mechanical
advance and nylon pads to insure long term smooth operation
� Adjustable vacuum advance, with lockout insert for mechanical
advance only operation
� Easy 3-wire hookup with isolate ground circuit and weather tight connector
� Steel alloy drive gear, compatible with either flat tappet or
hydraulic roller camshafts
� Race-proven high output magnetic pick assembly
� Recommended electronic breakerless coils with 0.7 Ohms or less of
primary resistance;ACCEL p/n's; 8145, 8145C, 8140HV, 140001 & 140008
� Compatible with CD ignition systems
so you can run with or without a CDI.
Dont know about the BILLETPROOF thing tho.
