battery relocation to boot for LC/LJ
#1 _uglybob_
Posted 20 June 2007 - 06:33 PM
so i just wanted to know how you guys that hav done it, did it and what are the regulations for doing this? (as in do you have to run the cabling outside the cab and stuff)
ben
#2 _uglybob_
Posted 29 June 2007 - 03:59 PM
Posted 29 June 2007 - 04:18 PM
http://www.gmh-toran...topic=17010&hl=
http://www.gmh-toran...battery in boot
To answer some of your Q's, battery must be vented outside the car, you ever seen a battery tray rust, they dont want you breathing in them fumes, and cable can run anywhere, just ensure it is properly protected where it passes thru steel etc so its not sliced and earth out.
Its an idea to advertise that it is there via the blue triangle etc for emergency crews incase of an accident and most motor sports require you to have an isolator accessible from the outside of the car for these reasons.
In any case i think spending the extra cash and switching to a sealed gell type battery, optima etc, is a worthy investment if only for size and the spill proof advantage.
Hope this helps.
Edited by ALX76, 29 June 2007 - 04:26 PM.
#4 _youngy_11_
Posted 29 June 2007 - 05:12 PM
#5 _David-UC_
Posted 29 June 2007 - 06:03 PM
They look good are made of reasonably tough plastic but I'm not up on any state regulations re-venting.
Good luck.
Posted 29 June 2007 - 07:07 PM
$250 to $400 dep on brand and size.How much would a gel battery be
P.S. on the top right of the page is my assistant, click and type in what you want.
Edited by ALX76, 29 June 2007 - 07:09 PM.
#7 _uglybob_
Posted 29 June 2007 - 08:24 PM
so basically you just need one of those plastic battery box jobies to wak you battery in and put rubber gromets in where you go though a panel with the cable.
thankyou.
Ben
Posted 29 June 2007 - 08:38 PM
Best your plastic box is vented to outside the car and not the boot.
#9 _Monkey_
Posted 29 June 2007 - 08:39 PM
The red cable in the link below is my battery cable wich runs along the chassis rail and into the boot
https://cache.gmh-to...73/100_9216.jpg
Posted 29 June 2007 - 09:51 PM
You can get them from most good electrical stores and they only cost a few bucks each.
Posted 30 June 2007 - 12:11 AM
Do you mean those grey screw together thingy-ma-bobs?I much prefer plastic cable glands to rubber grommets when going through sheet metal with heavy current cable.
Posted 30 June 2007 - 12:52 AM
#14 _uglybob_
Posted 30 June 2007 - 02:57 PM
how exactly do you vent the battery to outside the car??
thanks for the picture by the way monkey. thosea re some rather large breaks. (much larger than my own).
ben
#15 _uglybob_
Posted 30 June 2007 - 03:01 PM
#16 _gstar_
Posted 30 June 2007 - 03:39 PM
Posted 30 June 2007 - 05:55 PM
#18 _JBird_
Posted 03 July 2007 - 12:43 PM
#19 _JBird_
