Radiator setup
turbotrana
, Jan 23 2006 02:31 PM
8 replies to this topic
Posted 23 January 2006 - 02:31 PM
Originally in my Turbo 202 I had a V8 capacity 3 core (tanks top/bottom) radiator which performed well (from memory). I had to replace it cause old so I replaced it with a 5 core crossflow radiator(commodore style radiator) but it seems to rely more on the fan to keep it cool at idle than the 3 core did.
So by going 5 core I think I went backwards in cooling ability.
Anyone else had similar experience or can suggest a good size crossflow raditor to use.
I've got one of those Volvo fans that everyone says cools well but that bugger nearly draw 30amps from my testing which is a bit too much IMO. Nevertheless it does it job well.
#2 _Yella SLuR_
Posted 23 January 2006 - 03:08 PM
Do a search, this was discussed previously on the new forum. For some reason, which I've yet to fully get my brain around, 3 core was supposedly better.
#3 _devilsadvocate_
Posted 23 January 2006 - 03:37 PM
Is the only difference you notice while at idle?
It may well be the actual water holding capacity of the radiator that is a factor here.
Is the 5 core rad noticeably thicker than the 3 core you had? The 3 core may have held more water and had more of a time delay b4 it heated up and your electric fans? had to kick in to cool it down.
Posted 23 January 2006 - 05:11 PM
you may have adjusted the thermostat for the fans to a different setting too? Maybe it's not getting hotter, the fans are just kicking in more for that reason?
#5 _TUFF_
Posted 23 January 2006 - 05:52 PM
Out of curiosity what car did u get the 3 core radiator out of as i am looking for one atm.
TUFF
TUFF
#6 _Bomber Watson_
Posted 23 January 2006 - 09:53 PM
kingsies had them from waht i gather. v8 ones are no good cause the water necks are on the wrong side, unless you get a chev rad...
#7 _devilsadvocate_
Posted 23 January 2006 - 10:05 PM
You just ask for a HZ taxi rad.kingsies had them from waht i gather. v8 ones are no good cause the water necks are on the wrong side, unless you get a chev rad...
Posted 23 January 2006 - 11:03 PM
basically the old radiator is a HZ Taxi type one
The 5 core is heaps thicker and tubes are heaps closer together (this may be the problem)
The handpiece on my computer tells me what temp the engine is at and I can program what temp the fans come on. The current radiator is causing me no problems, just that it "seemed" that when I had a 3 core that it may have been doing a better job at cooling
#9 _Yella SLuR_
Posted 25 January 2006 - 11:04 PM
I saw it on a random search. Type "Desert Cooler" into the search for the other thread. Damn it, I'll do it:-
http://www.gmh-toran...l=desert cooler
Just as well, bit of a bum steer. Some good info here.
