LC-LJ Turning Circle
#1 _JBird_
Posted 30 June 2007 - 09:43 PM
I'm just trying to figure out if I need another wheel alignment or it just sucks. And until I get LSD I can't decrease it with my right foot
#2 _73LJWhiteSL_
Posted 01 July 2007 - 12:10 AM
Steve
Posted 01 July 2007 - 12:49 AM
Don't listen to the "Hoon"^
Edited by rodomo, 01 July 2007 - 12:51 AM.
#4 _JBird_
Posted 01 July 2007 - 01:56 AM
Too bad my handbrake doesn't work haha
Wheel alignment it is...Adjusting castor should decrease this right..
Posted 01 July 2007 - 02:13 AM
Turning circle is limited by rack travel.11.12m is pretty good.
I don't think altering castor will do you any good.
Any adjustment to camber or castor will alter toe-in but not effect turning circle.
#6 _JBird_
Posted 01 July 2007 - 03:08 AM
If adjusting castor doesn't help (which is hard to do because the radius rods feel like they're glued on). It might be a problem with my rack then. I had a new pinion put in because the last one got bent so badly.
My turning circle seems excessive thats all.
#7 _73LJWhiteSL_
Posted 01 July 2007 - 10:23 AM
The other thing is don't full lock it. You will find the wheels lay over and the circle generaly gets larger rather than smaller, particularly on gravel as the wheels skid. Much better to turn it to just before the wheels lay over.
Steve
#8 _why-psi_
Posted 10 July 2007 - 12:14 PM
Posted 10 July 2007 - 12:59 PM
Posted 10 July 2007 - 04:48 PM
