Removing spot welds
_CHOPPER_
Posted 23 January 2006 - 06:48 PM
_SSHatch_
Posted 23 January 2006 - 06:54 PM
Teng Tools actually have a special tool for doing this!
Will see if I can find the pic and post up for you!
Not Teng but if you have a look here they are a very similar tool to what I was talking about. Also some real nice but very expensive tools as well!!
Edited by SSHatch, 23 January 2006 - 07:02 PM.
_CHOPPER_
Posted 23 January 2006 - 07:01 PM
Posted 23 January 2006 - 09:00 PM
_CHOPPER_
Posted 23 January 2006 - 10:43 PM
_Pete_
Posted 23 January 2006 - 10:54 PM
Most welding consumable shops will sell spot weld drills as they normally run a bit sharpening service as well.
I could recommend a brisbane contact but thats probably no good to you.
_CHOPPER_
Posted 24 January 2006 - 06:46 PM
Posted 31 January 2006 - 08:08 PM
But who cares, it was a Gemmy
We also had this little air pressure handgun - jackhammer, that worked well getting the spot weld's off the actual chassis rail.
So take my advice, don't use chisels, jackhammers or flat head screwdrivers!! (especially on a Torana!)
But having said that, a Drill and a drill bit of the right size will work well... And the actual Tool for it will work nicely.
Posted 31 January 2006 - 08:21 PM
If you want a picture of a proper drill Ill take one tomorrow.
If your doing a dozen or so spot welds use a normal drill, if your doing half a cars worth spend the coin and get a proper drill.
_CHOPPER_
Posted 31 January 2006 - 10:30 PM
_CHOPPER_
Posted 05 February 2006 - 03:16 PM
Posted 05 February 2006 - 08:08 PM
lotsSo how much are the proper tools? What brands are better?
ill see what brand it is tomorrow.
_gtr161s_
Posted 11 February 2006 - 02:40 PM
_CHOPPER_
Posted 11 February 2006 - 03:09 PM
_TORANR AMORE_
Posted 11 February 2006 - 10:56 PM
I've managed to do this with an angle grinder and gently grind over the top of them, they heat up, and with a sudden whack with a hammer and screwdriver hey pop off. It doesnt always work as simple as that but generally works.
This works for the types of weld that are created by two electrodes with high current passing though the steel, heating it and thus melting it together at that point. It is not a perfect weld and there are inconsistencies withing the material between the two layers that are welded, in other words the material composition and strength is different within the weld as opposed to the two surfaces it has joined. This is the theory, so re-heating it will break this bond, all you will do is take up to a milimeter out of the surface with the anglegrinder heating it up, then whack it with a screwdriver and a hammer and it should pop open. For me this worked for 8 out of 10 welds, for an experienced tradesperson it would be 90% effective.
Posted 11 February 2006 - 11:02 PM
_CHOPPER_
Posted 12 February 2006 - 12:39 PM
_SSkid_
Posted 12 February 2006 - 03:34 PM
_CHOPPER_
Posted 12 February 2006 - 03:41 PM
_TORANR AMORE_
Posted 12 February 2006 - 07:46 PM
For example, if you look at my bonnet, which is just a skin, its perfect, There were support plates spot welded to the bonnet inbetween the skin and the inside structure, for the hinges. I had no drill at all. and this is how I got them out, as I was using the grinder anyway
Did the same thing for other sections of another car and it seemed to work well. I mentioned this to a mechanical & industrial engineer and he explained it to me in great detail all the way doen to the atomic level, of face centre cubic vs body centre cubic iron structures, bla bla bla etc etc etc,
A Drill works well too, if you've got one with the bits.
#21
_CHOPPER_
Posted 12 February 2006 - 09:03 PM
#22
_TORANR AMORE_
Posted 12 February 2006 - 09:44 PM
Chopped the roof off a Gemini and took it for a spin just for fun once. It looked good too as a convertible.
#23
_TORANASS_
Posted 13 February 2006 - 01:12 AM
I use a drill with 2 different sized bits like said above.. works simple and affective.
John
#24
_TORANR AMORE_
Posted 13 February 2006 - 02:51 PM
