LC Boot lock changing
#1 _dickiep_
Posted 01 July 2007 - 04:09 PM
Posted 01 July 2007 - 04:22 PM
Undo the two screws holding the thin piece of metal on the underside of the bootlid.i need to replace the boot lock and i cant work it out. ive got a new lock ready to go. the re is strip of metal on the underside of the lock which i cant pull off to get to the lock to remove the retainer pin to remove the lock assemby. Any ideas? i know not the best description.
Pry this piece of metal away from the bootlid (it will only come away... maybe 10mm). You wont be able to remove it completly. The lock should come out.
Posted 01 July 2007 - 05:58 PM
#4 _Flamenco_
Posted 01 July 2007 - 08:51 PM
#5 _dickiep_
Posted 01 July 2007 - 11:03 PM
Posted 01 July 2007 - 11:07 PM
Tim
#7 _dickiep_
Posted 01 July 2007 - 11:19 PM
Edited by dickiep, 01 July 2007 - 11:27 PM.
#8 _73LJWhiteSL_
Posted 02 July 2007 - 11:35 AM
You sure about not being able to remove it?Undo the two screws holding the thin piece of metal on the underside of the bootlid.i need to replace the boot lock and i cant work it out. ive got a new lock ready to go. the re is strip of metal on the underside of the lock which i cant pull off to get to the lock to remove the retainer pin to remove the lock assemby. Any ideas? i know not the best description.
When I swaped my boot lids over (after the bingle) I had to change the locks around. I pulled the lock retaining thing completely out.
Steve
#9 _dickiep_
Posted 02 July 2007 - 12:25 PM
#10 _Flamenco_
Posted 02 July 2007 - 01:56 PM
I think the Rares retainers for the lock are like the doorlocks - like a 'C' shape that you can pull right out but holden's retainer is almost like a keyhole - flat metal with a large hole that a slot joins to from underneath.
Sometimes you can get a flat bladed screwdriver between the rubber and retainer to 'jemmy' it off...
#11 _dickiep_
Posted 03 July 2007 - 04:23 PM
#12 _73LJWhiteSL_
Posted 03 July 2007 - 04:39 PM
With both my cars, i pulled the strip down and it came completely out, with a slot at the top. Mine are 73 cars, so maybe they changed it later from the solid one?
Steve
#13 _Flamenco_
Posted 03 July 2007 - 09:53 PM
Posted 03 July 2007 - 11:01 PM
Posted 03 July 2007 - 11:02 PM
#16 _dickiep_
Posted 04 July 2007 - 06:49 PM
#17 _73LJWhiteSL_
Posted 04 July 2007 - 07:11 PM
Steve
