Red 6's 202 rebuild thread
Posted 03 July 2007 - 11:31 AM
ive done cam swaps and head swaps multiple times and had no dramas with these, and ive pulled down a bottom end before but ive never actually assembled a fresh one.
so far i already have the following parts which will be involved in the rebuild:
-202 block supposedly virgin bore pulled from a low milage hq wagon.
-Yella Terra 186 type Stage 3 Head with all the usual work.
-Yella Terra 5007 roller rockers.
-Counterweighted Crank pulled from a different black motor.
-Starfire rods from same motor.
-Pacemaker extractors.
-Electronic Ignition.
thinking i will acquire the following parts before i pull the engine out of the car:
-New alloy timing gears (Jp?)
-ARP rod Bolts
-New Cam of some sort, i already have a dynotec stage 2 but want something which is better matched to the rest of the combo.
then obviously once engine is out i get all the machining done i will need to purchase a rebuild kit:
-What sort of Pistons should i be looking at?
-Should i use race series gaskets or will normal suffice for this combo?
-When i pull down the bottom end what parts do i take to the machining shop together to get machined.
-do i need to keep any parts in a specific order?
- I think that they need to fit the cam bearings and pistons to rods at the machine shop as you cant do this at home. what else do i need to get them to do while they have it to make life easy.
In the long run after its all sorted and run in:
-new 2 1/4 in exhaust
-upgrade from single stromberg to a WW2 or possibly a small set or tripple su's.
WHAT ARE PEOPLES THOUGHTS?
WHAT ELSE SHOULD I LOOK INTO DOING WHILE I HAVE THE ENGINE APART TO IMPROVE THE COMBO I ALREADY HAVE?
Posted 03 July 2007 - 01:15 PM
rods and main caps should be numbered starting from the front of the block.
Any brand name piston will do.
Take crank, rods and block (with caps) with you and anything else you want acid dipped (sump/rocker cover) and or machined i.e. head.
If you having the assembly balanced, good idea if done properly(not alot of machine shops do) then they will need your harmonic balancer, flywheel and pressure plate.
oh, before you send the block of to the shop, grab a die grinder or a bit in a drill and run over the oil gallery's removing any dags of cast hanging around.
Edited by ALX76, 03 July 2007 - 01:17 PM.
Posted 03 July 2007 - 06:12 PM
Posted 03 July 2007 - 06:23 PM
Rods are to be numbered once, both on the cap and corresponding rod, keeping that number next/above each other, if you follow me. (so number one rod will have a 1 on the cap and a 1 above it on the rod itseff.).
If it has been rebuilt before then it is prolly already numbered.
The numbered parts go back where they came from on reassembly.
Posted 03 July 2007 - 06:30 PM
should i be using the main and bearing caps from the red engine im am rebuilding or from the black motor the crank came out of?
i have the rods and caps assembled and in order that they came off the crank.
Posted 03 July 2007 - 06:53 PM
Assuming the rods belong to the crank u are using they should be numbered from where they came to go back onto their corrosponding journals.
If they are all mixed and matched, have the block with the mixed/new caps and and the mixed/new rods and have the block line bored and the crank/rods etc ballanced.
The machinest will number them for you.
Edited by ALX76, 03 July 2007 - 06:55 PM.
Posted 03 July 2007 - 10:15 PM
A few other things to maybe think about at the machine shop;
- Deck the block and head
- Bore and hone
- Check the tunnel alignment of the block/caps, incase it need to be linebored
- Even the rods and caps can be checked, and machined if necessary
- Machine the crank flange and flywheel face where it bolts to the flange, both surfaces are then perfect.
- Check out the crank, Polish, grind only if necessary
- Acid dip and crack test
- Crack test head
There is probably a million other things that you could do, But if you get all the basic checks done first and then machine whatever necesary you should be pretty right. It will pay off in the end, as it'd suck to assemble it all and then have a failure due to the tunnel being out of alignment or something stupid.
It will save you in the long run, If you do it right the first time then you only have to do it once..... Good luck with it, it's a good feeling once you assemble it all and then it runs sweet.
Les
_Squarepants_
Posted 05 July 2007 - 08:40 PM
If you're going to give this motor a hard time, I'd think about doing all fasteners in ARP. I.E. main cap bolts, head bolts,rocker studs, o/s flywheel bolts aswell as rod bolts. It's over kill, but depends on how you're going to drive it.
I have a tendancy towards ACL pistons and gaskets, but any reputable brand will do the job.
Otherwise, some very good advise in this thread.
Posted 07 July 2007 - 02:47 PM
_Keithy's_UC_
Posted 07 July 2007 - 03:11 PM
You'll enjoy your motor, a bit of work makes the old red motor sound hot!!
Keith
Posted 09 July 2007 - 10:19 PM
started looking into cams...
http://www.crowcams....e-Holden6.shtml
looking at a;
35603 or 35666
probly 35603 as crow said this was more aggresive and probly the most you could get away with with only a two barell carby.
still undecided on straight or helical cut gears.
however this is only slightly more aggressive than my current cam dynotec stage 2 so im unsure if ill bother.
current cam is;
in 30/70 ex 70/30 280 duration
thoughts or just a waste of money for little return?
Edited by red6, 09 July 2007 - 10:25 PM.
_Keithy's_UC_
Posted 10 July 2007 - 06:07 AM
Keith
_gtrtorana_
Posted 10 July 2007 - 09:51 AM
I just sent all my engine parts to the machinest 2 weeks ago (red block and blue crank) and he did not say anything about this modification. My block and crank are both the rope seal type.You will probably need to get the main seal journal of the (black) crank resized to suit the red motor
Posted 11 July 2007 - 05:08 PM
Les
_JBird_
Posted 11 July 2007 - 05:27 PM
_tyre fryer_
Posted 11 July 2007 - 05:53 PM
your car is my favourite on the forums.
I'm doing all the same things to my 202 as you did to yours before.. well... it shit itsef.
Heath is right i should learn from your mistake but I really don't drive mine that hard at all.. never rev over 4K.
anyways, jus wondering what your car goes like with all these mods minus the cam (that's later plans).
like obviously you race a few cars on the street. what kinda cars can you beat?
I know that sounds childish, but i just want a real cruiser until somone wants a drag on a saturday night then i can turn the wick up and go all out up to 100Km/h. what kinda revs were you doing on your engine? and how much better was the car compared to stock?
thanks.
Matt.
_timbotorrie_
Posted 11 July 2007 - 08:25 PM
one is a crow 604 grind, which is an xu1 grind i think. and another but i think your current cam is about the same size
Posted 12 July 2007 - 12:41 PM
les: the cam is done less than 10,000km and i put it in with new pushrods and lifters ect so im thinking ill just stick to this one ive got at the moment to keep costs down.
tim: ill let you know if im intersted in the cam for the next stage of development when i do tripples ect ect after i get tired of this combo.
tyrefryer: thanks mate, like everyone else on the forum has said you really need to do a cam to take proper advatage of the head you have. trust me you wont be happy with just bolting the head on.
to put this into perspective if "in theory" i had ever had any traffic light battles i would say with your yt head, 202 AND a cam you will keep up with vl's r31 skylines ect and most v6 commodores up till vs
without a cam it you probly wont
then just bolt on a ww2 or twin strombergs and you will quite comfortable beat them.
alot of this depends on the driver, diff gearing and that an lc is much lighter than a commodore ect. a uc is much heavier so this takes away that advantage a little.
my torana still has 2.78s tho so that really holds it back a bit.
good news is ive just made a small fortune on ebay tho so it looks like the rebuild will definetly be happening over the next month while i have access to another daily while the parents are away.
Posted 17 July 2007 - 06:04 PM
engine out by next week.
should i be looking at running flat top pistons?
Edited by red6, 17 July 2007 - 06:05 PM.
_uglybob_
Posted 17 July 2007 - 08:54 PM
i rekon go for the hq race series acl ones. they hav either the 2.2cc dish or the flat tops. dont really no how they would differ from each other its only 2 cc just giv the head a lick or something to bump it up. i hav the small dish with a 50cc head and thats haparantly 11.1 or around there according the the guru.
can anyone tell why you would go for one over the other??
#21
Posted 19 July 2007 - 02:49 PM
#22
_uglybob_
Posted 19 July 2007 - 08:43 PM
#23
Posted 19 July 2007 - 09:10 PM
#24
_uglybob_
Posted 20 July 2007 - 05:55 PM
#25
_timbotorrie_
Posted 20 July 2007 - 09:22 PM
you need to dial in the cam using a degree wheel and a dial indicator. its the only way to get it spot on matethe straight cuts turned up today they are CS6202 crow items the hardened steel ones which have the multiple keyways. which cam timing should i be looking at running? or do i need to provide more cam specs so you guys can tell me?
