Heres a list of the stuff I have for the conversion...308 LC
5spd Celica box
--> 308 bellhousing
Clutch
Thrust bearing
Flywheel
Two piece drive shaft (commodore one)
What other bits and pieces do I still need?
Auto to manual....what am i missing?
_01dencwe_
, Jan 24 2006 01:55 PM
6 replies to this topic
#1 _01dencwe_
Posted 24 January 2006 - 01:55 PM
#2 _draglc_
Posted 24 January 2006 - 02:33 PM
Dont forget the spigot bush, goes in the rear of your crank, the autos have a different one, so ull need to get that out, and get one to suit toyota box and 308 crank. You can get one from dellow or a lot of performance clutch places.
Manual pedal box?
Clutch setup? Linkages, cable or hydraulic?
All i can think of for the moment.
A1
Manual pedal box?
A1
#3 _Torana308_
Posted 24 January 2006 - 08:58 PM
Gearbox mount and cross member, wiring for reverse lights , shifter if its not with the box, Id doubt youll be using a two piece commodore shaft unless your planning to do some re engineering to the car and shaft. Sorry to sound silly but i know how many things i forgot or didnt think of when i started doing mine
#5 _01dencwe_
Posted 26 January 2006 - 05:00 PM
Hmmm there appears to be alot of things I overlooked...
Does $500 seem decent for all the stuff I listed?
#6 _draglc_
Posted 27 January 2006 - 09:01 AM
Yeh that sounds pretty decent, like Torana308 said, not quite sure about the tailshaft, you should be using just a normal torana one, to suit gearbox and diff of course.
#7 _01dencwe_
Posted 27 January 2006 - 04:17 PM
Oh i'm not using the commodore one just the yoke or whatever
