What is a Hydra trac?
#26 _UDLOSE_
Posted 23 July 2007 - 08:51 PM
Anyone driven on one? Do they put the power down when you stand on it or will they make an arse of you and single leg it? Are they recommended for racing or are they a off road thing?
#27 _Brewster_
Posted 08 August 2007 - 10:12 PM
http://www.4wdworld....oit/detroit.htm
And I'd like to know the same thing, are these things any good?
Posted 28 October 2008 - 07:00 PM
With a car like a commodore where they don't suffer anything like the weight transfer issues on the rear end they will work fine as you have similar weight over both rear wheels. With a weight transferring bastard like a Torana, they will be shit and will act much more like an open centre.
Are you talking about the clutch LSD or the Hydratrac acting more like an open centre?
Also can you explain weight transferring, does a V8 Commodore have less than a V8 Torana?
s
Edited by StephenSLR, 28 October 2008 - 07:03 PM.
#29 _ChiaLX_
Posted 30 October 2008 - 10:38 AM
what happens is you are more likely to break traction in a torana in the first place because the weight transfer will lift one side slightly and therefore lose traction on that side forcing the lsd to come in and out as the weight shifts.
hope that makes sense
#30
Posted 12 July 2013 - 10:58 AM
Old topic, but would I be correct in thinking that with a Hydratrac, unlike a normal LSD, when you jack the car and spin one wheel, the other won't spin?
Mine has been chattering it's arse off (basically like a locker). I went to Holden they gave me an additive, but it's still chattered until yesterday morning when there was a loud bang in the back. It's no longer noisey or chattering, but I jacked it and spun a wheel and the other didn't spin. I've never taken any notice before.
#31
Posted 22 July 2013 - 11:31 AM
So I gather no one can tell me for sure? I ran Holden they tried to tell me it was just a normal LSD. Unfortunately most of thier staff were still in nappies 15 years ago when these were new! HSV most of the engineers are retired.
#32
Posted 22 July 2013 - 01:38 PM
#33
Posted 22 July 2013 - 08:11 PM
Isn't viscous just a marketing gimmick much like magnatec oil, all LSD's operate in a viscous fluid lol.
#34
Posted 22 July 2013 - 09:49 PM
#35
Posted 22 July 2013 - 10:18 PM
The BTR Hydratrak is basically a hydraulic version of the Detroit Truetrac.
The Detroit Truetrac uses worm gears to transfer torque to the wheel with the most grip. The Hydratrak uses a sealed hydraulic coupler to transfer torque to the wheel with the most grip.
This is an article from Perth Street Car Vol 4. No 4 (1997).
I remember hearing stories of the Hydratrak overheating if you gave it a hard time.
Edited by ls2lxhatch, 22 July 2013 - 10:25 PM.
#36
Posted 22 July 2013 - 10:39 PM
Hydra tractor?
Posted 23 July 2013 - 12:17 AM
Hydra tractor?
I just want one...
#38
Posted 25 July 2013 - 03:19 PM
Thanks for the replies. I'm not sure if my diff is working as advertised though. The answer i got back was, "go do a burnout and see if it's working or not'.
#39
Posted 25 July 2013 - 03:39 PM
If one wheel turns and not the other then one would assume the LSD is not functioning.
#40
Posted 25 July 2013 - 09:16 PM
