Resistance coil HELP
#1 _steve253_
Posted 13 July 2007 - 07:37 PM
Posted 13 July 2007 - 07:41 PM
with a multimeter put neg probe on battery negative, pos probe on coil positive and you should be getting about 9 volts.
Put pos probe on coil negative and wind engine over by hand and tell us what you get.
If you live near Lisarow i can give you a coil.
Edited by FastEHHolden, 13 July 2007 - 07:45 PM.
#3 _steve253_
Posted 13 July 2007 - 07:45 PM
Edited by steve253, 13 July 2007 - 07:49 PM.
Posted 13 July 2007 - 07:49 PM
So one of the 2 wires to the positive on the coil is the resistor.
Posted 13 July 2007 - 07:50 PM
you need a coil marked "use with resistor"....I can give you one if you like.
#6 _steve253_
Posted 13 July 2007 - 07:52 PM
Edited by steve253, 13 July 2007 - 07:55 PM.
Posted 13 July 2007 - 08:04 PM
on the pos side of coil...one wire ballast wire (9V)...other is ignition wire (only has power when cranking)
Posted 13 July 2007 - 08:07 PM
If you were to be out for a drive on saturday arvo and passed Lisarow I could put you on the road to recovery.
#9 _steve253_
Posted 13 July 2007 - 08:27 PM
#10 _steve253_
Posted 15 July 2007 - 07:57 PM
