LC - Handbrake Cover
22 replies to this topic
#1 _CraigA_
_CraigA_
Posted 28 July 2007 - 10:59 AM
What was the original factory method of fixing the lower area of the handbrake cover?
Was it some sort of surround? Or just the carpet?
Mine is a mess and want to tidy it up.
Thanks,
Craig.
#2 _Flamenco_
_Flamenco_
Posted 28 July 2007 - 04:16 PM
Pretty sure it just sat underneath the carpet...
#3 _Feigz_
_Feigz_
Posted 28 July 2007 - 05:45 PM
Pretty sure that it has a wire base that is screwed to the floor and the carpet sits next to the vinyl. Haven't had one on mine for nearly four years. Something else for the shopping list.
#4 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 28 July 2007 - 06:28 PM
out of all the lc gtr's we have seen and worked on they tuck under the carpet..from factory
no wire or anything just tuck under the carpet
#5 _CraigA_
_CraigA_
Posted 29 July 2007 - 08:17 AM
Thanks for the replies.
Mine is just tucked under the carpet but keeps working its way out so I was hoping that there was something missing similar to the retainer mentioned.
Cheers,
Craig.
#6 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 29 July 2007 - 08:55 AM
i honestly think the same ^^^ as when i first seen them..i asked so what goes over the top of that to hold it down...
nothing, bit strange !!
#7 _LC870_
_LC870_
Posted 31 July 2007 - 08:07 PM
All of the LC torana range handbrake covers just tucked into the side of the carpet.
The LJ covers were designed differently and had a long tail on the back which was glued down on the tunnel and also the sealbelt bolt went through the middle.
I also have the genunie GMH patterns and the correct vinyl to make exact copies of these if anyone is interested.
#8 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 01 August 2007 - 08:25 AM
how much to make me one a handbrake cover to suit lj, we dont have any of those so if your offering
and also if you got them..gear shift cover suit lj...vinyl doesnt matter as they will be used as a template, so even the cheapest vinyl you got would be good
:D
Edited by boomfunk, 01 August 2007 - 08:26 AM.
#9 orangeLJ
Posted 01 August 2007 - 09:39 AM
^^ our upholstorer just finsished making the handbrake boot and gear shift boot for my old mans XU-1, did a pretty dandy job too. we supplied him with the old ones, he made a pattern and whipped em up.
#10 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 01 August 2007 - 09:46 AM
and have you still got the old ones.......
#11 orangeLJ
Posted 01 August 2007 - 11:07 AM
yeah, pretty sure we do. we stil have everything that was originally with the car, from the original bumpers, to the original hoodlining (although it is still in good knick its being used to recover the sunvisors)
why do you ask??
#12 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 01 August 2007 - 11:16 AM
well we will see what the other fella ^^^ comes up with and if thats no good then i wouldnt min getting some patterns for both the hand brake and gear...i think gear shift maybe same as lc but not sure.
Edited by boomfunk, 01 August 2007 - 11:28 AM.
#13 orangeLJ
Posted 01 August 2007 - 11:25 AM
i dont see why not.
#14 _LC870_
_LC870_
Posted 01 August 2007 - 09:23 PM
The handbrake covers are $30.00 each and the shifter boot i do for $25.00.
'As mentioned before i do have the genuine GMH patterns and use the correct stitch spacing and thread.
I can also do the opel gearbox shifter boot.
#15 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 02 August 2007 - 07:33 AM
Lc870, thank you but thats too expensive, im not concerned about stitch spacing and thread, or even vinyl, they can be made from canvas
im using it as a pattern to sell our own....
orangelj, would it be possible to organise something with those original patterns you got, even it you sent them to me them i copied them and sent them back?
or if you made a pattern for me and sent it,
#16 orangeLJ
Posted 02 August 2007 - 09:25 AM
yeah i will see what i can do, we put the new boot in last night, the old one doesnt have the "tail" people mentioned that went down to the seatbelts, but it was glued in around the edges, and from what we know was factory like it.
#17 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 02 August 2007 - 09:49 AM
oh ok, lj has to have the tail from factory...bugger !!
dont worry i will keep looking
thank you for your time orange :spoton:
#18 orangeLJ
Posted 02 August 2007 - 10:11 AM
no worries mate, it has a small tail, but as i said, not one that runs back to the seatbelt bolt.
good luck with it.
#19 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,294 posts
  • Car:ɐuɐɹoʇ
Posted 02 August 2007 - 12:31 PM
Hi
If the handbrake cover was under the carpet and fixed to the floor in some way - how do you adjust the handbrake without it being a major operation?
Just a thought.
Bazza
#20 orangeLJ
Posted 02 August 2007 - 12:51 PM
wasnt like permanently glued, looked like some form of contact adhesive. and how often do you adjust your handbrake??
that contact adhesive stuff stays fairly maleable for ages, so it can be pulled up and stuck down (although not as efective as the first ime) a few times.
im not saying it was factory, but definitely looked it, the car has been off the road since 1982.
#21 _CraigA_
_CraigA_
Posted 05 August 2007 - 08:41 PM
Obviously couldn't confirm the glued/not glued, but every unrestored car I saw at the AHD today had this type of trimming around the handbrake area. This included LC's and LJ's with original carpet.
#22 orangeLJ
Posted 06 August 2007 - 11:24 AM
we got the hole in our carpet trimmed with a vinyl edge, just didnt like the "hacked out" look that some have.
never seen anything like that but ^^
#23 RallyRed
  • 8,042 posts
Posted 20 April 2013 - 05:52 PM
.....old thread...time mooves on......just received a LC Roebuck handbrake cover from Boomfunk.....happy with it. All good.
