Do these Elect Dizzies fit LH/LX ?
#26 _pallbag_
Posted 11 November 2007 - 04:57 PM
And an aftermarket/perfomrance set ..
#27
Posted 11 November 2007 - 08:56 PM
In this day and age using a HEC 716 is the go, try to mount them away from the motor or at least in some fresh air for cooling as when they get too hot they split and stop working (as can be seen on 6cyl EA-EF falcons).
Buy aftermarket leads from Top Gun, Eagle etc. up to $100.
Personally anything with MSD on it is something I would rather not use. Some people have a lot of success with it though. Other people make a lot of money repairing them. Keep it simple and stick to the Bosch HEI.
JMHO
#28 _Yella SLuR_
Posted 11 November 2007 - 09:08 PM
Struggler, glad you said that, cause that's what I've done, just stuck with the Bosch HEI set up. So far no tears whatsoever. One of the best mods I've ever done.
#29
Posted 11 November 2007 - 11:25 PM
#30 _smokem_
Posted 12 November 2007 - 02:02 AM
ok rally hatch ive noticed nobody answered the last question u askedI've got one of the HEI Bosch jobbies sitting in the draw of my tool box, I was thinking about swapping it over for the oil filled one on the car now..... BUT!
On closer inspection of the Bosch one it says " IF YOU ARE RUNNING A MODIFIED IGNITION SYSTEM THEN DO NOT USE THIS COIL ...or your head will explode and monkeys will fly out your butt" Or something along those lines any way....
Is this just Bosch covering their ass' or could it mutate into another life form??
Any ideas on what voltage the bosch ones are???? Was not writen on my one, the lable is damaged prob right where it says voltage!!!!
And since nobody wants to answer my other post about MSD timing computers...
I'll ask it in here...Has any one used one before???? If so what are your thoughts on them???
and i thought id better answer ya
NO!!!
i havent used one but if your talkin about the hand held jobbie
thats the one im gettin so im keen on seeing if anyone else has used em aswell
#31 _Yella SLuR_
Posted 12 November 2007 - 05:37 PM
#32
Posted 13 November 2007 - 03:38 PM
#33 _Lostit_
Posted 13 November 2007 - 09:55 PM
#34 _Yella SLuR_
Posted 14 November 2007 - 05:42 PM
Edit: Sorry I can see the Forum, but can't log on or post from work anymores. Big brother is watching.
Edited by Yella SLuR, 14 November 2007 - 05:43 PM.
#35
Posted 14 November 2007 - 11:06 PM
Posted 14 November 2007 - 11:52 PM
#37 _Yella SLuR_
Posted 15 November 2007 - 12:55 AM
#38 _pallbag_
Posted 04 January 2008 - 07:06 PM
Tried to install mine today but the cap was fouling on a breather at the back of my manifold(Edelbrock Holden Perfomer) so mechanic said it will be OK to use my old cap, and is going to use a holden 6cyl rotar on it. The auto elect in the shed next door has similar set-up on his holden tilly ...
Does this sound OK - or should I opt for the ford one as mentioned previously ?
#39 _mumbo_
Posted 05 January 2008 - 08:56 AM
#40 _TORANASS_
Posted 12 January 2008 - 08:39 AM
John
#41
Posted 24 May 2010 - 07:27 PM
Edited by TerrA LX, 24 May 2010 - 07:33 PM.
#42 _Gunmetal LH_
Posted 25 May 2010 - 03:01 AM
