AIR SPEED
123 replies to this topic
#1 EunUCh
EunUCh
  • 2,771 posts
  • Car:japos
Posted 28 August 2007 - 03:49 PM
Is there anyone who who has had the privelige of using flow bench who can tell us what is the optimum area of intake port compared to valve throat area that gives best results (for the purpose which engine is built) for cylinder filling.obviously there are varibles involved but there must be some point where air speed thru port and thru valve hit the so called sweet spot,for example,do we want air speed thru throat faster than air speed thru port or vise versa or do we aim for same speed thru both throat and port.
#2 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 28 August 2007 - 06:03 PM
I'll be watching this thread!
Only because it's a really good question, but i dont think that you'll get too many people give you their secret out in the public like this! (Unfortunately!!)
Cheers!
#3 EunUCh
EunUCh
  • 2,771 posts
  • Car:japos
Posted 30 August 2007 - 01:30 PM
I agree that those sorts of figures would be kept close to chest by those who know or have a good idea of what the figure is,however I have managed to find on the net that a figure of 650 ft/sec is about the max,but still doesnt answer the question of the speed thru port/valve throat,my own thoughts would be to keep them the same. Anyone else got ideas to throw in,throw em in lets churn it over,after all we all want the best results from our engines and I figure a good place to start is put a bit of theory into what we are doing then go from there.The main reason for good air speed into cylinder is to obviously fill the cylinder quick and get as much as poss. in there.I have had personal exp. with a torana that was fitted with 253 ,twin 2in ex,big valve heads of well known manufactuer,mild cam,336 gears on 13's,roch.carb and the thing went worse than a stock 253 auto with wwstromy with 308 gears on 14's.only reason can come up with is that the big valves killed it.(both engines were in similar condition).a mate of mine has almost the same setup (same profile cam big valves)in a tonner and it has the same charactoristics as the torry did and his motor is fresh.hence the question where do we aim for with air speed,and once we know that what is the formulae for working out how much air/fuel do we get into the cylinder at a given air speed(keeping in mind of course wot purpose we build the engine for)
#4 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 30 August 2007 - 05:31 PM
Mmmm, where do I start. I'll see if I can cut and paste something later on.
#5 _finer70_
_finer70_
Posted 30 August 2007 - 07:46 PM
Speed does not equate to volume.
#6 _Toranamuk_
_Toranamuk_
Posted 31 August 2007 - 12:14 AM
Also a very important thing that i chase more than air speed, is swirl, & trying to aim the swirl direction so that it best fills the cylinder,,,
eg, if the inlet valve is on the front of the cylinder, you want to aim the airflow in a clockwise direction. This i believe will gain you more actual cylinder fill volume than air speed alone, but you still need good air speed whilst keeping your runner volume as low as possible if your building the engine for torque.
The next major thing to overcome is "pulsing" or "shudder". This interrupts the air volume at & around the specific valve lift & can drastically slow the air speed & volume.
Craig
#7 rodomo
  • 18,043 posts
Posted 31 August 2007 - 02:53 AM
Does 9" between the butterfly and the valve head mean anything? :blink:
#8 _threeblindmice_
_threeblindmice_
Posted 01 September 2007 - 09:28 AM
NOBALLSUC maybe your problem is elsewhere, if your secondaries come in to early it can cause a big loss of performance as the motor struggles to cope with all that fuel. Just a thought .A good secondary tuning guide in some of the Holley secondary spring kits
#9 _1QUICK LJ_
_1QUICK LJ_
Posted 01 September 2007 - 02:58 PM
ok first things first the 253 mentioned probably lost power due to the fact that the bigger valve heads induce 2 problems on a 253. firstly they overlap the top of the bore and actually hinder flow, the second problem is the heads were probably relieved in the chambers for the bigger valves which reduces the compression quite a bit, plus the you probably used a 4inch bore 308 head gasket which makes the compression issue even worse. then if you put a fairly big cam in that will bleed of even more compression which you didn't have much of in the first place so whats all this amount to ? an engine with no grunt. :rolleyes:
#10 _1QUICK LJ_
_1QUICK LJ_
Posted 01 September 2007 - 03:08 PM
with the head flow issue. i like to aim for air speed around 330-350 feet per second at peak torque rpm ie 4000rpm and about 640ft per sec at peak rpm. cross sectional area is also extremely important also as this dictates where the power curve will peak. it gets quite complicated. if you dont have accsess to a flow bench then it realy is hard to apply all the factors into the heads and know if you got it all right.
#11 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 01 September 2007 - 08:31 PM
NOBALLSUC, I'll give you my take on things......
Every cylinder head has a point of most restriction/smallest cross sectional area (CSA), some have 2 or 3. The best place for this to be is at the valve seat. The best heads act like a funnel, but are not shaped like one. Air needs greater CSA to turn a corner (ie in a bowl behind a valve). For best cylinder filling air speed has to be greatest at the valve seat. With your 253 fitting the bigger valves may have moved the lowest CSA to another part of the port, this is what happens with standard heads with big valves fitted and no bowl work.
1QUICKLJ, I have said this before, the fact that the valves hang over the edge of the bore is mainly irrelevant. As Toranamuk said, the majority of the air travels on the outside of the port, across the bowl and valve and heads toward the spark plug. The bore lip is not in the way. What works on a flow bench doesn't always transfer to reality. A flow bench measures air flow, an engine flows air and fuel. If the bore lip was a problem then Clevo's and BBC's would go better with the lip removed. They flow more air this way but make no more power.
EVERYONE, from my experience L34 sized valves are NOT needed for a mild 253 or 308. DON'T believe the hype, Yella Terra heads are WORSE performers than standard stock valve heads, both on an engine and on a flow bench. Any head with L34 valves NEEDS a fair bit of bowl work to perform effectively. In my experience standard sized valve HQ heads with a good valve seat job and very little clean up work on the bowl and short side radius perform remarkably well.
For computer aided engine design including CSA calculations check out....
http://www.maxraceso...ipemax36xp2.htm
This is all based on MY personal experience, please feel free to comment.
#12 TerrA LX
Posted 01 September 2007 - 09:37 PM
So where is the best head job in town?
#13 _willo_
_willo_
Posted 01 September 2007 - 09:43 PM
mitchell
#14 _Herne_
_Herne_
Posted 01 September 2007 - 09:48 PM
PMSL rotflmao hehehehe, I knew the answer before I read it, just wasn't expecting it to come from willo.
keep up the good work willo.
Herne
#15 _threeblindmice_
_threeblindmice_
Posted 02 September 2007 - 09:29 AM
Struggler, can this problem be compensated and or moved to a different rev range by the choice of the carburettor size?
#16 EunUCh
EunUCh
  • 2,771 posts
  • Car:japos
Posted 02 September 2007 - 04:14 PM
Dont know if these are in calculator but here we go;
MEAN GAS SPEED THRU PORT =PISTON SPEED/60 x D squared/d squared
MEAN GAS SPEED THRU VALVE = PISTON SPEED/60 x Dsquared/VxLxPI
D=Dia of piston,d=dia of port,V=valve throat diameter(measured under valve),
L=lift of valve.All measurements in inches and ft/sec.
As already stated CSA plays a big part in air speed as well valve lift,rpm,port shape/size and it does get a bit complex,if we crunch a few numbers with the above formulae it is easy to see that what seems a fairly minor change in port or valve throat area (CSA) we end up with major differences in air speed which obviously affects cylinder filling, hence torque/power.One would assume(i hate that word) that if we aim for max air speed thru valve throat(at some given rpm) that we should aim for the same value thru port and try and maintain the speed probably from the carby/s? and keep the air stream as straight and smooth as possible right to the valve.could be why one carb per cylinder work better(in most cases) than one single carb.Back to poor little 253 problem,yes it had 308 head gasket dont know how far the valves were sunk and the cam was around 208@50 270 lift,all would have had some affect,but man it was woefull.if i was computer savy i'd know how to add this link but i'm not so i'll have to type it out http://www.racetech.com.au/custom.htm
#17 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 03 September 2007 - 09:27 AM
Choking the engine with a smaller carb is a bandaid fix at best. It can make things a bit better but if the heads are poorly designed/ported then the engine will always be lacking.
#18 _threeblindmice_
_threeblindmice_
Posted 04 September 2007 - 11:15 AM
My suggestion of a smaller carbie, was only a thought to make it more drivable, not a solution to his problems . As a car often has to stay the way it is for some time, before it can be rectified .I do love the way the technical side of the Forum have analysed this problem.
#19 _revmaniac_
_revmaniac_
Posted 06 September 2007 - 06:21 PM
on this day 06/09/07 i would suggest getting the latest and second latest issues of street machine and read bob kotmels "stage rite"...he explains that rd v8 heads are unlike anything else on the planet....and that "steve gay" located i think in macay is THE BEST MAN to get to port red heads as he is responsible for a legendary torana that ran into the 11's with stock valved stock port red heads...they were ported but only in the inportant areas like the bowls and seats. The owner was known to win considerable bets at the strip by offering to remove the heads to prove the port entries were untouched and "as cast"......and on a side note quench is sometimes more important than swirl.....but not always....and quench is the clearance between piston and the filled in part of the chamber in the head....helps transfer heat from the piston crown to the cyl head where the coolant can remove it...important in high efficiency engines as combustion pressures are very high
#20 _1QUICK LJ_
_1QUICK LJ_
Posted 06 September 2007 - 11:19 PM
ok if that is the case then there would be no point in relieving the chambers when you fit bigger valves, its a well known fact that when you fit bigger valves theres hardly any increase in flow or horsepower unless the chamber is releived to a certain point to unshroud the intake valve to take advantage of the bigger valve, there is still a certain amount of air and fuel flowing around the side of the intake valve where too much valve shrouding does affect power output.
Edited by 1QUICK LJ, 06 September 2007 - 11:21 PM.
#21 _1QUICK LJ_
_1QUICK LJ_
Posted 06 September 2007 - 11:32 PM
as for BBC and clevos theres simply not enough room to take out enough bore edge to make any real difference to shrouding. ive seen clevos make more power with a smaller valve but same size port i wonder why that is ? seeing as you would be effectively flowing less air across the valve with a smaller window for the air to flow.
#22 _1QUICK LJ_
_1QUICK LJ_
Posted 07 September 2007 - 01:41 AM
the clevo head is a canted setup which really cant be compared to a holden head, as with canted valve setups the higher the lift the less the valve becomes shrouded. im not disagreeing that the air flows across the valve but it still flows around the entire valve to some degree, the flow also changes its flow pattern during different rpm and valve lifts. all i was saying is a L34 size valve in a 253 is a waste of time, there is nothing to be gained on a 253 but lost torque and no more hp. ive been porting and modifying heads for over 15 years and done all sorts of testing. and yes valve shrouding does affect power. as far as im concerned it is very relevent if it has worsened the flow to any degree that affects power.
Edited by 1QUICK LJ, 07 September 2007 - 01:45 AM.
#23 EunUCh
EunUCh
  • 2,771 posts
  • Car:japos
Posted 08 September 2007 - 12:35 PM
As already said big valves/throats dont always make more torque/power and as also already said that smaller valves work better in some cases,would the fitting of smaller valves also involve reduction in valve throat area or is flow gain achieved by the fact that when you fit a smaller valve it is unshrouded in chamber?also if we use a smaller valve and reduce valve throat area accordingly would this not let us use a camshaft of higher lift to increase the curtain area under the valve resulting in maintaining good velocity over the valve lift operating range and at the same time better flow because of increased curtain area.I've not had any experience in building hot engines but because of the plan to build up up something abit better i figured a good place to start would be do a bit of research to find out on which way to go,so far this topic has yielded some execelent info,and the article mentioned obout the standard valve/port on the torana sounds very feasible as i have mate who is a mechanic and he did his mates 202 in similar manner,was only a daily driver but the results accordin to him were quite outstanding.as this discussion continues my personal point of view on big valves big ports big flow numbers dont mean big power,i say this with regret but i think a lot of folk suffer from what i call glossy magazine syndrome (from which i used to suffer),and bigger is probably only better in the area of air cleaner size!.as 1quiklj has said use the airspeed he aims for,flow comes from very carefull removal/adding metal in bow area and around where the valve stem guide protrudes.
#24 _1QUICK LJ_
_1QUICK LJ_
Posted 08 September 2007 - 02:57 PM
NOBALLSUC. your way of thinking is on the right track. i to beleive that too many people get sucked in to the bigger is better theory. one more thing on the shrouding issue, yes the air does travel across the valve towards the plug area as struggler has pointed out, but thats not the complete picture. the air only flows across the valve when the air speed is fairly high, at lowerlift and also lower rpm the shrouded side of the valve and the short side raidius of the port flows a fair bit of air which can make a difference to the width of the engines powerband and its ability to make good torque. so all im saying is you cant focus on just one factor of head flow you have to look at the whole picture. i have the upmost respect for struggler i am certainly not trying to challenge his knowledge. this is just my point of veiw from what i have learnt from over 20 years of playing with engines. :spoton:
#25 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 08 September 2007 - 08:40 PM
No problem 1QUICKLJ, I'm old enough to know there is more than one way to do this stuff, there is no real right or wrong. How I do it is to concentrate the flow across the valve to the spark plug. I only unshroud the intake in the area around the spark plug. This is what works for me (maybe I could be doing it better ?). This does NOT mean this is the only way that is effective.
Its also worth noting that HQ308 heads respond differently to other heads (Ford, Chev etc) to port changes.
