hey on one of my threads a member said that a S/B chev fuel pump would fit on my 186 just wanted to know if any chev s/b one would fit if I have to get a certain type? and I guess it would be helpful to know the flow rate for a standard red 186 pump
cheers guys
S/B chev fuel pump into a red 186?
_superlowuc_
, Jan 29 2006 04:14 PM
7 replies to this topic
#1 _superlowuc_
Posted 29 January 2006 - 04:14 PM
#2 _Bomber Watson_
Posted 29 January 2006 - 05:42 PM
that would have been me. not sure if any one will fit, heres some picks of mine:
i havan't actualy tryed it on a running motor yet but from what i have gathered, as far as mechy pumps go this is the hot setup.
#3 _superlowuc_
Posted 30 January 2006 - 12:42 AM
hey thanks LC boi I could not remmeber who had posted it. thanks for the photos I am going down to day to get a pump and the photos helped alot as I am in the states and I do not have my 186 pump with me but I can print the photo out
cheers antony
cheers antony
#4 _superlowuc_
Posted 30 January 2006 - 07:46 AM
hey real happy got a brand new one for $14.99 USD at autozone
hey you using any other S/b chev stuff on your 202
antony
antony
Posted 30 January 2006 - 07:56 AM
Don't forget if using this fuel pump for your proposed blow thru set up it will need to be boost referenced.
#6 _superlowuc_
Posted 30 January 2006 - 10:00 AM
hey I am pretty new to engine tech what does boost referenced mean, I am guessing it has somethink to do with when the turbo kicks in the fuel flow at boost?
#7 _CHOPPER_
Posted 30 January 2006 - 04:49 PM
So what are these Chev pumps worth in Aussie dollars in an Aussie store?
#8 _Bomber Watson_
Posted 30 January 2006 - 07:30 PM
have a look in a parts peddler, usualy about $50.
superlowuc: yes thats basicaly boost referenced. it uses a special fuel pressure reg with a diaphram in it, as the boost comes on the fuel flow/pressure gets upped. not cheep brother, but there good.
oh, and just for the record, the motor that it's on in those picks is the 202 i'm rebuilding. it ran 12.9 with that pump....so they can hadle a bit atleast. i personaly recon it would be worth a lot more than that, but i'll never test it. the 202 in it's newly born state will probalby never see more than a high 13.
Edited by lc boi, 30 January 2006 - 07:33 PM.
