Tilt switches
#1 _gstar_
Posted 30 August 2007 - 06:13 PM
Anyway, As a result of the incident all contractors are required to review there ROP systems and submit safe work statements, hazard analysis blah blah to the dpi.
So we have a ride on mower, big unit like councils do footy fields with. I have masterminded a plan to make a device out of a couple of mercury switches to cut the engine if the mower was driven across a slope greater than 20 degrees, to ensure operators could not roll over plant when travelling on inappropriate surfaces.
So my question is to implement this, i would need to run the two switches parralell, mounted to something, on angles. id hook it to the ignition wire, or the seat emergency stop. Then id need a overide button so you could get it started again and back away from the slope.
Is there a better way to do this, And is this achivable?
Posted 30 August 2007 - 06:48 PM
Maybe hit up dick smith...but R32 GTR Nissans have a pair of accelerometers for the 4WD system..They might be worth a shot.
#3 _gstar_
Posted 30 August 2007 - 06:51 PM
Whats the go with these accelorometers? i know some of the bigger trucks have something similair. no idea what they do
Posted 30 August 2007 - 08:06 PM
What about a Wii remote?
#5 _Flamenco_
Posted 02 September 2007 - 10:43 PM
#6 _ljbob_
Posted 03 September 2007 - 09:17 PM
I don't think you should fit an override button. At lest not one that the operator could use without reporting it.
BoB
#7 _ljbob_
Posted 03 September 2007 - 09:19 PM
BoB
#8 _Flamenco_
Posted 04 September 2007 - 02:12 AM
Posted 04 September 2007 - 05:04 PM
Posted 05 September 2007 - 02:58 PM
#11 _revmaniac_
Posted 05 September 2007 - 09:38 PM
Posted 14 September 2007 - 08:59 PM
Interestin problem though, Would be good to see how you get around it!
Posted 24 September 2007 - 02:42 PM
