hi again guys sorry about all the Questions but I am trying to get as much stuff for my UC while I am in the States as possable.
I am guessing if I use stronger spring I will be able to get a bit higher RPM, is it worth it or will it help on a 186?
Anyway I was wondering if any one out there could tell me what the coil bind and the spring rate is for the springs on a red 186. I am try to work out if I can buy some S/B chev D/valve that will fit, or even just stronger reg springs
looking back I should have taken an owers manual with me, but you live and learn
cheer antony
valve springs
_superlowuc_
, Jan 30 2006 07:33 AM
6 replies to this topic
#1 _superlowuc_
Posted 30 January 2006 - 07:33 AM
Posted 30 January 2006 - 07:59 AM
Buy a set of Chev LT1 springs, any brand, should be easy to get (if anything they will be overkill but you could always sell them when you get home).
#3 _CHOPPER_
Posted 30 January 2006 - 04:46 PM
Just get springs to suit the intended cam and rocker ratio.
#4 _Bomber Watson_
Posted 30 January 2006 - 07:38 PM
agreed.
that said, lt1 ones will do the job...
#5 _superlowuc_
Posted 31 January 2006 - 08:47 AM
thanks guys I went into the parts store today and I am looking at srings with:
LT1 single springs [email protected] seat load 385@ 1.200 open load do you think that will work with my red 186 or is the open load to much or to little the set of 16 is around $75 usd would I get a set cheaper than that in OZ and ship it to NZ?
thanks again
antony
thanks again
antony
#6 _superlowuc_
Posted 31 January 2006 - 10:09 AM
the guy gave me the wrong price its $130 usd so if I can get them cheaper in OZ I will the cam grind is XU-1 spec that what I was told when I got it the rpm is 2500 to 6500 ish but I have not pulled it out and had a look on it, the springs are from com cams part # 26918-12 ( behive stye) ant help is great
thanks again
antony
thanks again
antony
Posted 31 January 2006 - 04:17 PM
US $130 is far too much, you can get AUS $ 80 sets here. Ask for a cheaper brand, ie Speed Pro or Pioneer.
Check these out.... http://www.jegs.com/...rchItemId=91663
US $36 is closer to the mark, and they are made by Crane.
