chev / Red holden 6 compatablity
13 replies to this topic
#1 _superlowuc_
_superlowuc_
Posted 30 January 2006 - 10:08 AM
they sorry to keep on asking. what proformance parts are interchangable from chev S/B to holden 186/202
on my other threads I have found out fuel pump roller rockers and valve spring ant thing else you guys know about?
thanks again I am greatful for you input
antony
#2 _Bomber Watson_
Posted 30 January 2006 - 07:00 PM
roller rockers arn't interchangeable. myself and rexrob (now racyrabbit i think) tryed this a wile ago and decided its not worth it. they will fit but you have to fit bigger studs...not sure how big my head has 3/8 ones and it needed bigger. 7/16th i think we worked out.
#3 _CHOPPER_
_CHOPPER_
Posted 30 January 2006 - 09:36 PM
SBC roller rockers will bolt straight onto all Holden 6 Red heads, except for 173 and 202 heads.
#4 _Bomber Watson_
Posted 30 January 2006 - 09:45 PM
fair enough
just saying the ones I TRYED didn't fit onto MY HEAD which is a 149 head with 3/8 studs. to go bigger studs would require takign to much out of the bosses imo. they would be weak.
so, i suppose the only advice i can give is be carefull what you get.
#5 _CHOPPER_
_CHOPPER_
Posted 30 January 2006 - 09:55 PM
Just so there is no confusion...
Standard SBC rockers have a 3/8" stud. Just like all Holden 6 heads, except for 173 and 202 heads. YT 5007 is the part number for YT roller rockers.
And as lcboi said, there are 7/16" stud size as well.
#6 _Bomber Watson_
Posted 30 January 2006 - 10:05 PM
aha, so i was trying the wrong ones ;p
#7 _82911_
_82911_
Posted 30 January 2006 - 10:26 PM
But all screw in studs weather 3/8 or 7/16 UNF are 7/16UNC on the end that screws into the head....
Cheers Greg..
#8 _superlowuc_
_superlowuc_
Posted 31 January 2006 - 12:45 AM
yeah I bought 3/8 stud and 1.5 ratio roller rocker so I think they will work, I am kind of wondering if GM in the states made an strait 6 engine that was the same as the 186/202 etc anyone know?
thanks again
#9 _82911_
_82911_
Posted 31 January 2006 - 07:31 AM
Blue flame 6 is similar in a lot of ways though much,much bigger...
And very old now.
You will be fine with the parts you bought!
Cheers Greg..
#10 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 31 January 2006 - 02:25 PM
lifters fit
#11 _CHOPPER_
_CHOPPER_
Posted 31 January 2006 - 10:18 PM
Cheers Greg..
Greg, we were originally talking about the rockers, not the studs.
#12 _82911_
_82911_
Posted 01 February 2006 - 07:19 AM
I know Chop...
I was replying to....
:tease:
Cheers Greg..
#13 _CHOPPER_
_CHOPPER_
Posted 01 February 2006 - 07:31 PM
No problem. It's unusual for you to make a mistake.
#14 _82911_
_82911_
Posted 01 February 2006 - 09:23 PM
Oh I can assure you it happens... :blink:
Cheers Greg..
