Short Spark Plugs
9 replies to this topic
#1 _LH350_
_LH350_
Posted 30 January 2006 - 01:08 PM
Guys,
Because the headers are too close to the top of the spark plugs on the crate 350 an easy fix would be to get spark plugs with a shorter porcelain section (say 10mm shorter than standard). I have called NGK who couldn't help and Bosch were clueless.
Does anyone know whether such plugs exist - they may be cheaper than modifying the headers!!
Any ideas appreciated :fool:
#2 72XU1
72XU1
  • 34 posts
Posted 30 January 2006 - 01:30 PM
Hi
My brother has a similar problem with a small block Chev motor in an EH. It is only with a couple of cylinders but he (and the original builder) uses/used the correct heat range motor mower plugs. Yep strange but true. "Desparate problems require desparate solutions".
Bazza
#3 MRLXSS
  • 12,396 posts
Posted 30 January 2006 - 01:43 PM
Thats interesting ^^ Who would have thought great idea though!
#4 _Flamenco_
_Flamenco_
Posted 30 January 2006 - 02:18 PM
I would have thought you could use different leads with a right angled end like the commo HEI dist leads have at the cap? (Just a guess)
#5 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 30 January 2006 - 08:37 PM
I recall that Accel used to make short style spark plugs, according to this they still may...
http://accel.carshop...s_id/1304/0437S
#6 rodomo
  • 17,999 posts
Posted 01 February 2006 - 12:15 AM
Try Champion CJ8 lawn mower plugs :D
RACV MAN
#7 surfmaster
surfmaster
    Marineboy
  • 2,019 posts
Posted 01 February 2006 - 12:32 AM
RACV MAN
How often should the blades be changed?
#8 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 01 February 2006 - 09:06 AM
^dunno, but the hardest part is getting all the lawn clippings out of your boot :tease:
#9 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 02 February 2006 - 06:29 PM
Accel plugs are still available, approx $70 for a set of 8. They're between 1/4"-3/8" shorter than std.
#10 _Lostit_
_Lostit_
Posted 02 February 2006 - 06:34 PM
Just depends what heat range you want... i encountered same problem with my number 8 sparkplug and there is no sparkplug we found.. then got told to look at motorcycle plugs .. guess what yeap it works but it fouls up .. but it works i can live with changing the plug each 5000km )
