2600S Head Part Number?
#1 _VerdoroGTR_
Posted 31 January 2006 - 09:16 AM
Could anyone help with a couple of GM part numbers ?
In particular the No. for an original 2600s Head but also interested
in the number for the LC GTR 2 Barrell manifold and stromberg carb.
David
#2 _gm3300_
Posted 31 January 2006 - 10:08 AM
On the top cover of the carb you will find a number stamped which should be
23-3041. The 23 is the code for Holden, and the 3041 is the application, LC GTR
161S 69/71 WW Stromberg Carb. The other number is, the single digit is the year
and the two digit number is week of manufacture.
The head part number info can be confusing because the number that is cast into it is not necessarily its replacement part number. For example an LC XU1 head replacement part number is 2820105, this number is not what is cast into the top of the head which is 2815843.
The same situation applies to most of the other red six heads, a common casting is used for different applications, when the head is complete with its correct valves, springs etc it would be packed in its appropriate replacement part box with its replacement part number.
With this in mind, the casting number for the 2600S is 7438296, this is the number on a late 70 car so its possible that earlier cars had a different casting number. Could you post up your numbers as i'm looking to set up a list of head casting numbers, if anyone else has numbers to add let me know
grant
#3 _VerdoroGTR_
Posted 31 January 2006 - 09:42 PM
Although I have not got my hads on a 2600S block as yet I thought I
should be armed with the correct casting number for an original head so
I can check every red 6 head I find. Same goes for the carbie and manifold, I have
seen a few 2 barrell carbies and manifolds around but wanted to try and get
one with right numbers if possible.
Why do people delight in removing factory bit's and replacing them with
what ever bodgie stuff they have lying around ???
The search goes on
Posted 01 February 2006 - 01:11 PM
Engine No: 2600s26566
Head: 7436296 K150 7H
Carb 233041 9 47 M905 ??
Hope this helps
"Cheers"
2600s
#5 _VerdoroGTR_
Posted 01 February 2006 - 01:32 PM
All info is appreciated, I notice your head number is slightly different to
the one quoted by gm3300 but as he says this may be a difference in year
model . The Carbie number seems to agree though. If it is not too much of
a pain next time your under the hood I woudn't mind finding what number they have on the manifold as well.
David
Posted 01 February 2006 - 01:36 PM
"Cheers"
2600s
Alf
Posted 01 February 2006 - 08:01 PM
The manifold number is 7434446-P further down the manifol the numbers 114 and Holden appear.
Hope this helps you out!
"Cheers"
Alf
#8 _VerdoroGTR_
Posted 01 February 2006 - 08:48 PM
Thanks for the extra trouble , Now thanks to yourself
and gm3300 I can go hunting for my missing bits armed
with the right numbers .
Regards
David (VerdoroGTR)
Posted 01 February 2006 - 10:02 PM
#10 _gm3300_
Posted 03 February 2006 - 05:16 PM
The numbers are correct, the K150 is the date code for the head casting which is K(October) 15 (day of the month) 0 (1970). Remember "I" is not used because it can be confused with "1".Head: 7438296 K150 7H
Carb 233041 9 47
The carb is for LC 161S 69/70 and was made in the 47th week of 1969. Although this seems a long way of the cars production date, it's possible it's a spare part, or it was in a batch that was put aside, and other carbs were supplied and used before this lot. The carb on my 6/72 GTR is coded 1-37 so it's nearly a year from the cars build date, these things happen with production items.
hope this helps
grant
#11 _gm3300_
Posted 03 February 2006 - 08:57 PM
7438296 and cast date B100, or Feb 10th 1970, so there is another option if your looking for the right number. The date code seems to tie in with 2600s's car in being cast around a month before the car was built, but bear in mind this may not always be the case.
grant
Posted 03 February 2006 - 09:52 PM
thats the number my 2600 has on the head. The inlet manifold is a different cast number to the book also.7438296 and cast date B100, or Feb 10th 1970, so there is another option if your looking for the right number. The date code seems to tie in with 2600s's car in being cast around a month before the car was built, but bear in mind this may not always be the case.
grant
