rear suspension
Posted 20 September 2007 - 05:52 PM
but i was looking at the height, (i put super lows in) and the left rear seems to be higher than the right rear. they both same everything in the back, so wat wud it be?
any suggestions how to level it out? or shud i jsut take it back to mechanics n get him to even it out, n not hav my car for another day?
thanks
sammy
#2 _rhysandhisLJ_
Posted 20 September 2007 - 07:03 PM
Cheers,
Rhys.
Posted 20 September 2007 - 07:44 PM
Drive it for a day or two and let it settle. Then have another look on flat ground and if your not happy take it back.
Did you post a while ago about the way this car sits?
Edited by rodomo, 20 September 2007 - 07:45 PM.
Posted 21 September 2007 - 06:02 PM
nah i dont think i posted one bout how the car sits.
Posted 21 September 2007 - 06:26 PM
Posted 21 September 2007 - 11:52 PM
well i do know the rear end will eventually need to be done too.
just found somthing else now, the front left spring creaks wen u stop, and u can hear it creak wen u push on that side. is that an adjustment or just needs to settle in?
Posted 22 September 2007 - 01:21 AM
Take it back, or have it inspected first by another mechanic (someone like pedders charges around $20 and you get the list) and then go back with a list of things you want fixed.
Posted 22 September 2007 - 04:23 PM
before i said it looks like ther rear left wheel is higher than the right, well its the left side that is higher than the right. front and rear left side is higher. wud that be adjustments of the shocks or?
just gets me that u spend money to make it better n then theres something that isnt right n it shud be.
Posted 22 September 2007 - 04:33 PM
#10 _the gts_
Posted 22 September 2007 - 07:16 PM
That was probably me.
Sammy I may be able to help a bit with this mate as I had the same problem after I put new suspension in.
My car had only done 80,000k's from new before i butchered it and still had the original springs in, all original no accidents etc.
the chances are that the problem lies with the front springs.
1. Jack the front end up and in the lower wishbone (control arm) you will see a small hole. through that hole you should be able to see the end of the spring coil. if not fix that problem first.
2. if that doesnt work pull the springs out and look up inside the X-member. you will see 4 pring type things that locate the springs. there may be a tell tale sign that these are not letting the spring seating properly, wear mark etc. if that is the case you have to bend them a bit. I used a bluntened chisel and club hammer.
later someone told me that some aftermarket spring makers use different thickness wires.
I pulled my front end out about 20 times before I found this out, drove me F*cking insane.
any questions send me a PM
#11 _the gts_
Posted 24 September 2007 - 04:56 PM
im due for a service pretty soon so i might as well just wait till then n let him hava look if no change has been made.
#13 _the gts_
Posted 24 September 2007 - 11:37 PM
if you have problems send me a pm and i will take some pics to show you what i mean. my front end is apart at the moment
Posted 25 September 2007 - 08:30 PM
The front creek is probably the new bushes tightened while the car was still jacked up instead of ride height as suggested by other forum members and if you put nolothane in then maybe they didnt put enough grease.
The rear ride height issue could be:
1. they placed the slightly taller spring on the LH side instead of the RH( drivers side)
2. NEw springs take time to settle. Ive seen them drop 3/4" in weeks from new(on the front anyway).
3. the Insulator fell out of the RH side and car is actually lower on RH (not Higher on LH side).
4. They didnt place the new spring in exact grooves of the rubber insulator as the old one and now it sits higher. If it comes down then you know its chewed right through the insulator due to improper placement.
5. The RH front spring is lower causing LH rear to rise.
#15 _rorym_
Posted 27 September 2007 - 11:41 PM
Posted 28 September 2007 - 11:08 AM
Make sure you report back and let us all know the result!
Posted 30 September 2007 - 02:46 PM
i jacked up the car, n hada quick squiz, i looked thru the hole to see where the sprong finishes and i can see where the end of the spring is, and it does look like it not sitting right. also the back right spring doesnt seem to be sitting properly either.
the creaking is louder now, n is giving me the shits. im not 100% sure/correct but i think mechanic said he put rubber bushes in, n polythene? (prob got that wrong) where the front end mounts to the frame.
i'll take a pic of it tomorrow so i ppl can see it.
brett i was working at a house off forest rd right on the corner near the cemetary, had quick look at shubes, man thats a nice car.
Posted 30 September 2007 - 03:45 PM
