Calipar Clearance 14' Sprintmasters
_boynuz_
, Nov 16 2005 01:38 AM
8 replies to this topic
#1 _boynuz_
Posted 16 November 2005 - 01:38 AM
Hi i have a vl turbo diff that i am converting over to fit my lc but want to keep my 14' sprintmasters.
If i got blank vl disks then got them re drilled for torana stud pattern will the calipars clear the wheels.
Or is their a better setup i can use for the rear while keeping my sprintmasters.
On the front i have lx disks and calipars.
Posted 16 November 2005 - 02:30 PM
They should fit
Posted 16 November 2005 - 07:21 PM
Did I hear a hint of unsureness from the brake specialist?
Posted 16 November 2005 - 09:02 PM
If I had a sprintmaster wheel here I'd try it on a diff and confirm
However I don't
I have seen Commodore brakes under 14" wheels before so I assume it should fit
Depends however on the clearance inside the rim
Till you try it you'll never know
However I don't
Posted 17 November 2005 - 12:49 PM
and might non-genuine Sprintmasters be different to the originals and so on?
Posted 17 November 2005 - 02:24 PM
This looks like a question for ............... CHOPPER
Posted 17 November 2005 - 08:52 PM
Damn datto i want a piece of that golden ass
Are u sure there 14inch sprintmasters?
N i always thought the Vl turbos had 15inch wheels disc brake rear end carried over to vn which use's a 15inch wheel! Could be wrong..
Stedz
Stedz
Posted 17 November 2005 - 09:28 PM
Yes VLT was 15"
VN had 14" unless it was V8 or specced with FE2 suspension so I know the brakes fit under a 14 on a commodore. VB-VS non IRS shared the same caliper and disc so all same there.
In theory as a commodore runs a front wheel drive offset of (approx) +43mm a torana with a (guessing) +6 offset should have enough wheel clearance for the caliper
But until its actually tried in real life its still just a guess (assumption)
#9 _boynuz_
Posted 18 November 2005 - 12:53 AM
They are 14' sprintmasters, After doing some research you are correct dattoman some Vn's Came out with 14' steel wheels.
A friend was saying the 14' steel wheels fit but not 14' mags as the 14' steel wheels have more clearance.
I will have to try and see if they clear, Hopefully they do as i like the sprintmasters..
