Just wondering what model Crane HI6 is best to suit a Holden 6 with a VK electronic dizzy. There seems to be a few variants but not sure which is best to suit this dizzy set up.
Crane Fireball HI6
_gtrtorana_
, Oct 12 2007 09:47 PM
6 replies to this topic
#1 _gtrtorana_
Posted 12 October 2007 - 09:47 PM
#2 _gtrtorana_
Posted 12 October 2007 - 10:20 PM
Just another quick one, I curently have a points dizzy converted to electronic with a bosch module bolted to inner guard, could the HI6 be wired into this system or would I have to use the VK dizzy as previously asked in above question? Any help appreciated.
#3 _Bomber Watson_
Posted 13 October 2007 - 04:48 AM
hi6 should have a wire for points ignitons.
the bosch module would be bypassed eather way.
prolly best off going a vk dizzy, so long as its only a mild motor.
#4 _gtrtorana_
Posted 13 October 2007 - 07:19 AM
The motor is pretty moded and has around 250hp.so long as its only a mild motor
#5 _gtrtorana_
Posted 14 October 2007 - 08:07 AM
bump...
I am looking at purchasing one of these very soon so any help would be appreciated. Should I be getting HI6, HI6R or HI6S.
#6 _v8slrtorana_
Posted 14 October 2007 - 11:50 AM
Use a plain old HI6. Will do the job perfectly.
Use the VK dizzy as it has the magnetic pickup. Can't see what power levels has to do with using a vk dizzy.
If you use the converted points dizzy, i pretty sure you still need to use the module to get the pickup to work. Not 100% sure on that but.
Always where you can, use a mag pickup to fire a CDI.
Posted 14 October 2007 - 01:59 PM
Try the ignition section here http://www.cranecams...Engine Controls
