lh or lx
Posted 12 October 2007 - 09:54 PM
Still trying to work out the origins of my car, but chassis number CLX043770M is definitely LX yeah? Cheers.
#2 _SLR_6_
Posted 12 October 2007 - 09:57 PM
Edited by SLR_6, 12 October 2007 - 09:58 PM.
#3 _Yella SLuR_
Posted 12 October 2007 - 10:11 PM
#4 _Flamenco_
Posted 13 October 2007 - 01:34 AM
Posted 14 October 2007 - 01:20 PM
where do the rear seatbelts mount, through the c pillar or the parcel shelf?
#6 _fatlh5000_
Posted 14 October 2007 - 02:44 PM
My mate has an early model LX SLR 5000, where the seatbelts are mounted to the pillar, just like on my LH.
FYI
#7 _UDLOSE_
Posted 15 October 2007 - 07:46 PM
Posted 15 October 2007 - 08:29 PM
cheers, I thought that may be the case.where do the rear seatbelts mount, through the c pillar or the parcel shelf?
FYI
if his chassis number was ALX.... it could have the pillar mount seatbelts.
there are a couple of sheet metal differences between LH and LX but I would assume the early LX's would be the same as the LH's
Posted 16 October 2007 - 10:20 AM
Posted 19 October 2007 - 10:55 AM
The number i posted was actually the chassis number from the chassis itself near the radiator. Not the comp plate. Those plates are different so Im just trying to work out what the actual body of the car is. The seatbelts mount to the pillar (see photo) and it has the 4 pedals (see photo) I always thought this was an LH thing? Or is it both? Perhaps its an early LX body?
My comp plates are for a 11-76 LX with a BLXO chassis number, so would that match up to the body do you think, if the chassis number near the radiator had perhaps been changed at some time? Or is it all too dodgey?
Im really just wondering if even though this body has an LX chassis number is it an LH or early LX around 76? Cheers for the info.
SEATBELTS
PEDALS
PLATE INFO
Posted 19 October 2007 - 10:59 AM
If yours has Pillar mounted seatbelts and a CLX chassis number, something a bit dodgy going on there.
Tim
Posted 19 October 2007 - 12:12 PM
Is the car currently registered? Or has in been registered in the past? Check old rego stickers or something...
If your intention is to just get it registered and on the road... There are ways around it... If its a wizz bang SLR5000 or something i would be a bit worried...
Edited by MRLXSS, 19 October 2007 - 12:14 PM.
Posted 19 October 2007 - 12:42 PM
yeah its not a wizz bang SLR 5000 or anything so not overly stressed. Just trying to work it out.
It has BLX on the chassis (comp plate) number but CLX on the chassis (rail) number and pillar mounted seatbelts. Bit odd huh?
Thinkin I might get a cheap LX and move all the good bits across to make a real LX as the body is pretty rusty anyway.
Posted 22 October 2007 - 01:13 PM
Posted 22 October 2007 - 02:14 PM
Posted 22 October 2007 - 02:36 PM
Posted 22 October 2007 - 03:31 PM
Do the numbers corresponding t othe CLX and BLX match?
ie, one is BLX12345, and the other is CLX12345?
*Ignore me.... i just read through all the posts again... *
Edited by MRLXSS, 22 October 2007 - 03:32 PM.
#18 _JBM_
Posted 22 October 2007 - 04:11 PM
James
Posted 22 October 2007 - 04:25 PM
Mine is BLX, Sept 76 and parcel shelf mounted seatbelts.
Looks like an LH shell, Chassis # restamped and dodgy tags.....
Grant..
Posted 22 October 2007 - 04:56 PM
Ie. (from what I have learnt here):
PARCEL SHELF MOUNTED BELTS
YELLOW NEEDLE SLR DASH
COLUMN MOUNTED HEADLIGHT DIPPERS
SMOOTH SHEET METAL INSIDE THE BOOTS/TAILIGHTS AREA
SILVER FASCIA
Anything i missed?
Anyone got a half decent but cheap LX shell in Melbs?
#21 _rhysandhisLJ_
Posted 22 October 2007 - 05:23 PM
My lx sedan had the original woodgrain dash?Woodgrain dash wasn't available on LX.
#22 _hatcheddan_
Posted 22 October 2007 - 07:01 PM
LX SL's had the light wood grain and LH SL, L20 & L32 SLR had the dark wood grainMy lx sedan had the original woodgrain dash?Woodgrain dash wasn't available on LX.
#23 _trna76hb_
Posted 23 October 2007 - 07:51 PM
Ian
#24
Posted 23 October 2007 - 08:39 PM
BLX is way too late for belts on the pillar the fact it has CLX chassis number and BLX compliance number should ring alarm bells, add that third element of the belts and you have a mess on your hands. Pillar belts were LH shells only. Yes early LX had it, but they were left over shells from LH. Don't go on dashes and things, people change them all the time.
LH had dark woodgrain, LX was lighter, silver dashes only came in LX SLR and SS.
#25 _Eddie_
Posted 25 February 2008 - 01:44 PM
