Liam,
Heres the info and pics i can give thats u asked via PM, I have other pics but need to dig them up.
What i done to fit the 265's
The inner wheel tubs I cut the 1" spacer out with a grinder, then done slits so the panel wouldnt distort and pull, and get a better finish, Then hammered and welded the tub against the chassis rail NOTE this all shows up in the boot So "strip the boot out and remove fuel tank"
This is the finished result from behind, THIS IS ALSO WHAT 355LXSS IS DOING His pics are better spoken for
Now the Diff I had professionally cut But measured it up myself,
:First thing You need to Have your wheels and sit in and i measured mine up with an Adjustable FAKE AXLE supplied by the engineers Which you bolt the wheels upto and adjust according to where the wheels sit Once your happy lock it and take it in, they will weld it all up and cut the housing according + axles
:I had my shocker mounts moved in by 5mm to Just get clearance
:My hatch with the Convo pro 15x8.5 with the 5 & 3/4inch back space I had my diff Cut to 1386mm OVER DRUM This was My measurement to suit my parts But this should give a rough Idea
:The Gaurd Lips have been rolled
:Im running the BF GOODRICH 265/50/15 Have Standard 6cyl springs in the back end witch the gaurd sits Just on the verge of the tyre so Looks low, I still will be dropping it an inch But may run into scraping problems on the outer gaurd
I hope this Can Help you on your mission If you have any other questions or need pics PM Me and ill get back to you,
Goodluck
Marc
