Battery to Body ground
#1 _The Baron_
Posted 15 October 2007 - 09:16 PM
What was the original setup for the Battery to Body grounding in an LX V8?
I have all the original wiring for the engine bay but this connection eludes me.
Also what was the connection for the anti-diesel solenoid for the Rochester? The car had a Holley on it so the engine wiring loom has been hacked up.
I can fix the loom good as new but the tacho wire is joined to a dark blue wire that does not go back to the main connectors. It just resurfaces along the loom and appears to be for the anti-diesel solenoid.
I have identified all of the other connections as per standard LX/LH.
The engine loom has 6 connections on one plug and 2 on another.
Plug 1 -6 wires
Power to fuses box -Red
Ignition �Yellow
Alternator - Can�t remember-Brown?
Starter solenoid-Purple
Temp-Green
Oil Pressure- Blue
Plug 2 -2 wires
Tacho light pink
Coil resistor (yellow wire) bypass wire-Brown.
And then the A9X cooling fan control circuit for the relay came of the ignition circuit too.
Lots of fun;)
Posted 15 October 2007 - 10:15 PM
Posted 15 October 2007 - 10:19 PM
maybe this helps?I am just up to fixing all the years of bodgie wiring.
What was the original setup for the Battery to Body grounding in an LX V8? It goes from the neg terminal to a bolt in the rad suport panel just in front of the battery
Also what was the connection for the anti-diesel solenoid for the Rochester? The car had a Holley on it so the engine wiring loom has been hacked up. Oh joy, i can help with the wiring here, you'll need pics
I can fix the loom good as new but the tacho wire is joined to a dark blue wire that does not go back to the main connectors. It just resurfaces along the loom and appears to be for the anti-diesel solenoid. Tony, can you send me some pics of what you have there
Plug 1 -6 wires
Ignition �Yellow
Alternator - Can�t remember-Brown? yes
Temp-Green
Oil Pressure- Blue
Plug 2 -2 wires
Tacho light pink
And then the A9X cooling fan control circuit for the relay came of the ignition circuit too. it comes from the alternator and goes to the anti diesoling solinoid. it's hard to explain without pics
Lots of fun;)
Posted 16 October 2007 - 12:56 PM
I can help you out with a custom made heavy duty earth cable if you want. If originality isn't a problem, I'd probably go from the battery -ve to one of the larger front bumper support mounting bolts instead of the rad support panel.
#5 _The Baron_
Posted 16 October 2007 - 08:09 PM
I will look at it this weekend when I am out of the desert.
Posted 17 October 2007 - 08:14 AM
Hi Guys.Plug 1 -6 wires
Ignition �Yellow
Temp-Green
Oil Pressure- Blue
Plug 2 -2 wires
Tacho light pink
From memory, the pink is ignition +ve supply (to carby solenoid etc).
The tacho signal wire (from -ve coil terminal) is brown, as is the alternator light wire (these 2 are easy to mix up).
The yellow wire is the only one that goes to the coil +ve. The ballast by-pass is done inside the harness between the ignition switch & the engine harness plug (where the yellow & dull pink join).
Dr Terry
