still tilting
Posted 16 October 2007 - 10:36 PM
the springs are sitting correctly. and the front end has been built totally and been put in not long ago(1 month) i just bought some new wheels, 14 x 7's with 205/60/14 on front and 225/60/14 on rear.
does anyone know why the car tilts up on the left?
my thinking cap is overheated, so maybe the torana genius's here could help me out.
thanks
sammy
#2 _shunty_
Posted 17 October 2007 - 07:54 AM
Posted 17 October 2007 - 08:58 AM
Posted 17 October 2007 - 09:05 AM
#5 _73LJWhiteSL_
Posted 17 October 2007 - 10:43 AM
I've just given up. Its close enough
Steve
Posted 17 October 2007 - 11:15 AM
i not too sure bout if the springs hav been measured free or compressed. im thikin i might take it too pedders n see wat they come up with. the tilt is noticable so i wana get it right.
#7 _Toranaman24_
Posted 17 October 2007 - 02:41 PM
#8 _TORANR AMORE_
Posted 17 October 2007 - 03:14 PM
If that doesn't make much of a difference then change them with another pair, with the tallest/toughest one on the RHS (drivers side)
Cheers,
Rick.
Posted 17 October 2007 - 07:49 PM
#10 _Monkey_
Posted 17 October 2007 - 07:56 PM
#11 _2wild4u_
Posted 17 October 2007 - 10:46 PM
#12 _NURVUS_
Posted 18 October 2007 - 10:42 AM
It'd make a good B.S. session at the pub, tell em' its got an Aussie street race kit.
Another thing i've just thought of but you probably have too.. Do you have anything heavy in the boot like a jack and spare wheel etc.?
Edited by NURVUS, 18 October 2007 - 10:56 AM.
#13 _TORANR AMORE_
Posted 18 October 2007 - 11:01 AM
If the car has ever bounced through a big ditch or something at high speed then the chassis can be slightly twisted,....
Cheers,
Rick.
#14 _why-psi_
Posted 19 October 2007 - 12:31 PM
Posted 19 October 2007 - 08:18 PM
my spare wheel is on the left, and the jack is on the right, i might move that over just to see if that makes any difference.
shud i go to pedders and ask them to hava look? maybe it is that the springs need to be swapped each side. if the chassis is twisted how stuffed up will i be with that? cost wise and fix wise.
thanks heaps guys for ur help, keep it comin n i'll help out with info as much as i can
sammy
#16 _Pete_
Posted 19 October 2007 - 10:06 PM
You said it happened after the springs were changed, my guess is there not sitting exactly right.
#17 _NURVUS_
Posted 19 October 2007 - 11:07 PM
Agreed. See your spring guy.Your chassis wont be bent............
Even at worst, if your chassis was twisted, the cost to repair would not be worth it for such a small amount of difference.
Don't worry, i discovered today my new 9 inch housing is bent, wish i had of seen that before it was shortened and the brackets fitted.
#18 _the gts_
Posted 20 October 2007 - 01:24 AM
I had the same problem
