Hey, Just wondering where i can buy new flywheel bolts.
Les
Flywheel Bolts
mrlctorana
, Feb 01 2006 06:11 PM
4 replies to this topic
Posted 01 February 2006 - 06:11 PM
Posted 01 February 2006 - 08:14 PM
www.americanautos.com.au
Looks like you can only get ARP as stock one are NLA
#3 _82911_
Posted 01 February 2006 - 09:21 PM
Would suggest you use 2 packets of ARP SBC converter bolts. These are 3/8UNFx3/4" they come with a nut which you won't need. BUT... what they do come with is a trick little chamfered edge chromoly washer that grips the bolt shank when tightened and helps to stop them coming loose.
Don't forget the LOCTITE.... and around 65ft/lbs on the torque wrench, even thought the manual says 55ft/lbs the extra 10lbs is ok with a grade 8 bolt.
If the flywheel has come loose previously, then I also suggest you run a bastard file lightly over the crank flange to ensure it is still flat.
Cheers Greg..
Cheers Greg..
#4 _EXLXSL_
Posted 02 February 2006 - 06:56 PM
Nut and bolt place? Coventry Fasteners in South Burnie have helped me with bolts but it helps if you have a sample. Can get the right length, thread and grade.
Posted 04 February 2006 - 10:33 PM
Thanks Guys, Appreciate it. Will Check them out and see what i can find.
Les
Les
