I have found a 9" diff that says it will fit a lh torana. Its non lsd but with a spooled locking mechanism. It is going for $380 so i reckoned this was too good an opportunity to pass up. The main things i was worried about the fitting were: The width. are lh and uc toranas the same width across and the suspension mounts, are the trailing arm mounts the same between the models.
I know i will have to change my driveshaft but that wasnt going to be too much of a problem. If anyone has any advice on this or knows of any other things i should watch out for then it would be great. Apparently this diff was from a dirt track car.
9" diff for lh torana to fit uc?
_workinprogress_
, Nov 16 2005 12:00 PM
2 replies to this topic
_workinprogress_
Posted 16 November 2005 - 12:00 PM
_ultrabluea9x_
Posted 16 November 2005 - 03:22 PM
the diff wll not fit if it came out of an lh,,,,,,
the lh/lx floor pans are different than a uc ,the upper arms location pivots on a uc floorpan are in a different position ,length wise the same ,you will need to relocate the inner brackets on the diff itself not a big issue but it will have to be done
_workinprogress_
Posted 16 November 2005 - 04:45 PM
^sigh^ Oh well it was a nice hope. It seemed like to good of an oppurtunity to pass up incase it would work. Cheers for your help
