Help with VIN numbers
#1 _Leakey_
Posted 01 February 2006 - 07:46 PM
Can anyone tell me what these nos. mean?
VIN : J586898
Body No: M0586898
Chassy No: CLX049107
Trim No: 1886-67V
Any help would be appreciated.
Thanks - Leakey
#2 _SLR5000_
Posted 01 February 2006 - 08:03 PM
VIN matches body number so thats okay.
Ask for all the numbers on the body identification plate. Thats the plate on the passenger side.
Trim No: 1886-67V Brown vinyl.
Ask for the number stamped into right hand frame member assembly. Thats right near the cannister in the engine bay, often this nees the dirt wiped away to see number.
That number should match the number on the saftey compliance plate on the drivers side.
let us know how you go.
Garry
Posted 01 February 2006 - 08:06 PM
#4 _Leakey_
Posted 01 February 2006 - 08:11 PM
Hey nice pics from Bathurst!!
I'll be pissed if it isnt what its supposed to be, but might be able
to do a better deal..........
What should I be looking for to confirm it is a 6 cylinder SS?
Cheers, Leakey
Posted 01 February 2006 - 08:16 PM
Date of Introduction: February 1976
Total Number Built: 49,902
(incl. 8,527 hatchbacks)
Models Available: S sedan (4 & 6 cylinder)
SL sedan (4 & 6 cylinder)
SL/R sedan (6 cylinder & V8)
SL Hatchback (6 cylinder & V8)
SS Hatchback (6 cylinder & V8)
A9X option available with 5.0 SL/R & 5.0 SS models
Engines Available: 1.9 litre (1900), 4 cylinder
2.8 litre (2850), 6 cylinder (173ci)
3.3 litre (3300), 6 cylinder (202ci)
4.2 litre, V8 (253ci)
5.0 litre, V8 (308ci)
Transmissions Available: 3-speed manual (6 cylinder)
4-speed manual (4 cylinder, 3.3L 6-cylinder & V8)
3-speed automatic (4 & 6 cylinder, V8)
Differential Ratios: 4 cylinder (1900) - 3.9 manual, 3.55 auto
6 cylinder (2850) - 3.36 manual, 2.78 auto
6 cylinder (3300) - 3.08 manual, 2.78 auto
V8 (4.2) - 2.78 manual, 2.78 auto
V8 (5.0) - 2.78 manual, 2.78 auto
2.60:1 diff & T10 (4 spd) gearbox
available with A9X option
Brakes: Front:
S models - drums
SL, SL/R & SS models - power-assisted discs (254mm)
A9X model - discs (293mm)
Rear:
S, SL, SL/R & SS models - drums (228mm)
Instruments / Controls: S & SL models:
Speedo, odometer, fuel gauge, foot-operated park-brake, brake warning light, hi-beam indicator, turn signal indicator, generator warning light, oil pressure warning light, temperature warning light clock (SL only)
SL/R & SS models:
Speedo, odometer, fuel gauge, foot-operated park-brake, brake warning light, hi-beam indicator, turn signal indicator, battery charge gauge, oil pressure gauge, water temperature gauge, tachometer, alternator warning light
Interior Dimensions:
(Sedan)
Front leg room: 1021mm (40.2 inches)
Rear leg room: 843mm (33.1 inches)
Front headroom: 937mm (36.9 inches)
Rear headroom: 919mm (36.2 inches)
Front shoulder room: 1372mm (54.0 inches)
Rear shoulder room: 1364mm (53.7 inches)
Glass area: 23,835 sq. cm (3695.5 sq. in.)
Exterior Dimensions:
(Sedan)
Total length: 4509mm (177.5 inches)
Total width: 1704mm (67.1 inches)
Total height: 1331mm (52.5 inches)
Wheelbase: 2586mm (101.8 inches)
Front track: 1400mm (55.1 inches)
Rear track: 1372mm (54 inches)
Kerb weight: 1143 - 1183kg (2520 - 2609lb)
Turning circle: 10.97m (36 ft.)
Fuel tank capacity: 55 litres (12 gallons)
Cargo capacity: .31 cu. mt (10.8 cu. ft.)
(Hatchback)
Rear leg room: 775mm (30.5 inches)
Front headroom: 932mm (36.7 inches)
Rear headroom: 916mm (36.1 inches)
Rear shoulder room: 1367mm (53.9 inches)
Glass area: 24,903 sq. cm (3860.1 sq. in.)
(Hatchback)
Total height: 1326mm (52.2 inches)
Kerb weight: 1170 - 1209kg (2580 - 2666lb)
Fuel tank capacity: 52.5 litres (11.5 gallons)
Prices at time of introduction: S 1900 4-door sedan - $4,345
SL 1900 4-door sedan - $4,813
S 2850 4-door sedan - $4,584
SL 2850 4-door sedan - $5,249
SL/R 3300 4-door sedan - $5,798
S 4.2L 4-door sedan - $6,027
SL 4.2L 4-door sedan - $6,284
SL/R 4.2L 4-door sedan - $6,485
SL/R 5.0L 4-door sedan - $6,485
SL 3300 hatchback - $5,683
SS 3300 hatchback - $6,088
SS 4.2 V8 hatchback - $6,813
SS 5.0 V8 hatchback - $7,275
Body Codes
MODEL CODE BODY ENGINE
S 8UG69 Four-door Four
SL 8UH69 Four-door Four
SL 8UH77 Three-door Four
S 8VB69 Four-door Six
SL 8VC69 Four-door Six
S 8VB69 Four-door V8
SL 8VC69 Four-door V8
SL 8VC77 Three-door Six
SL 8VC77 Three-door V8
SL/R3300 8VD69 Four-door Six
SL/R4200 8VD69 Four-door V8
SL/R5000 8VD69 Four-door V8
A9X 8VD69 Four-door V8
SS 8VD77 Three-door V8
A9X 8VD77 Three-door V8
Paint Codes
PAINT NAME BERGER/DULUX ICI CODE GMH CODE PAINT TYPE
Absinth Yellow 1886/15949 1D008 Solid
Antelope 1894/15940 2G006 Metallic
Aquarius 1914/17778 Solid
Atlantis Blue 1934/30525 2B002 Metallic
Bordeaux /17773 2F003 Metallic
Caribbean Turquoise 1935/30526 2B013 Metallic
Chamios 1887/15950 1G009 Solid
Contessa Gold 1896/15942 2D002 Metallic
Cotillion White /15951 1J007 Solid
Deauville Blue /15944 2B016 Metallic
Durham Beige /15952 1G016 Solid
Dynasty Gold 1936/30527 2D004 Metallic
Flamenco Red 1926/30517 1F007 Solid
Jade Green /15945 2C010 Metallic
Jasmine Yellow 1927/30518 1D108 Solid
Madeira Red 1928/30519 1F034 Solid
Mandarin Red 1890/15953 1F072 Solid
Mint Julep 1915/17779 Solid
Opaline Blue 1929/30520 1B074 Solid
Palais White 1930/30521 1J001 Solid
Panama Green 1931/30522 1C002 Solid
Papaya 1916/17777 1E020 Solid
Persian Sand 1925/15946 2G024 Metallic
Persian Sand MK II /30183 2G023 Metallic
Royal Plum /17774 2A005 Metallic
Saddle Tan /30528 2G027 Metallic
Sierra Tan /17776 2G003 Metallic
Super Mint 1938/30529 2C009 Metallic
Tuxedo Black 2214/15991 Solid
Ultra Blue 1932/30523 1B104 Solid
Valencia Orange 1933/30524 1E028 Solid
Windsor Blue 1939/30530 2B023 Metallic
Trim Codes
TRIM NAME GMH TRIM CODE TRIM CODE
Chamois 60A (vinyl) and 60B (chevron) 17053/17214
Flax XS5 (vinyl)*
Sienna 65A (vinyl) and 65B (chevron)
Slate Black 18V (vinyl) and 18X (ranier)
Tan 67V (vinyl) and 67Y (chevron) 17057/17117
* Available on all LX models (except SLR5000 and SS 5 litre models) and was available for all colour combinations
Edited by GML-31, 01 February 2006 - 08:19 PM.
#6 _Leakey_
Posted 01 February 2006 - 08:40 PM
Now the only one missing is my bloody one!!!!!!!!!!!
That would be SS 3300.
I am guessing, going by the SLR numbers being all the same for all engines
that I need to look for 8VD77 on the plate somewhere.
Sound right?
Thanks again guys.
- Leakey
#7 _SLR5000_
Posted 01 February 2006 - 08:56 PM
Original engine prefix for the six cylinder SS "HL" followed by engine number.
I would post all the numbers here.
Good luck, but most important check all those numbers before handing over the cash.
Garry
Posted 01 February 2006 - 09:12 PM
#9 _Leakey_
Posted 01 February 2006 - 09:23 PM
I see her on Friday morning. (the owner)
Even though she's rough, (the car, not the owner)
I think the asking price is OK.
If not a genuine SS, if it has the right bits, I will
still grab it, hopefully for a bit less and dump that
V8 in to it, rather than restoring it to factory.
Thanks for your help mate.
- Leakey
#10 _Leakey_
Posted 01 February 2006 - 09:26 PM
I am really looking forward to posting some pics.
As I mentioned in the last post, she's a real roughy,
but if genuine, I think a great restoration project.
If not what she claims to be, then the project will
take on a different flavour, V8 etc.
Thanks for your advice again.
Leakey
#11 _keaton_
Posted 01 February 2006 - 10:21 PM
#12 _Torana482HP_
Posted 02 February 2006 - 03:44 PM
also says it in the body no. ex. ALH ****** M or ALX ****** M.
Regards Anthony.
#13 _Eddie_
Posted 02 February 2006 - 05:24 PM
It depicted what was the model, body, motor, place of manufacture, production number etc... Anyone? Maybe there should be a sticky somewhere or a tech page explaining fully how to intrepret the VIN and corresponding ID plates
#14 _JBM_
Posted 02 February 2006 - 08:53 PM
8 is for Holden vehicle.
D is trim code, SS for hatch or SL/R for sedan.
- C is SL and B is for S.
77 is body code hatch, 69 is sedan.
L is for 3.3 L20 engine.
- Z is 5.0 L34 not offered on LX.
- T is 5.0 L31 also used for road version of A9X.
- R is 4.2 L32
- D is 2.8 LD# not offered on SS.
The next letter will be the model year code.
- D for 74.
- E for 75, not sure after that.
The rest of the number is to do with the assembly line and vehicle id, J4 is in Melbourne and the H at the end also indicates a Melbourne car.
James
Edited by JBM, 02 February 2006 - 08:59 PM.
#15 _Torana482HP_
Posted 02 February 2006 - 11:26 PM
Here are the numbers on my Body ID Tag...
Model - LH8VD69
Body No. - 426199M
Trim - 1869-12X
Paint - 567-15336
L32 M20 GU7
VIN Tag....
8D69RDJ426199H
Complience Tag....
4-74 ALH 002758 M
But my Chassis Number Is......
ALH 002788.
Now my mate tells me that the original paint is a silver colour and i can see the original paint in some spots where the new paint has come off.
And he tells me that the interior is the light blue colour, which is what i have and its in perfect nick.
All the slr gear is on the car as well and still has the original engine (although i have my mates 253 in it at the moment cause the original is stuffed) original M20 trans and 2.78 banjo diff. So i think the car is a full original slr.
Judging by the chassis number i reckon the car was built at about may/june 74 not march 74 and someone changed the saftey complience plate with one that says it was built in march.
Whats everyone else think about this? i was really worried at first when i noticed the numbers were different but then with a bit of research i came up with the answer that just the safety plate has been changed.
Regards Anthony.
#16 _SLR5000_
Posted 03 February 2006 - 10:27 AM
Your Paint is Sable Metallic. Your interior is Ash vinyl with cloth inserts.
Saftey compliance plate on the drivers side you have posted this ALH 002758 M & you have put your chassis number as ALH 002788, I think you will find if you double check the vehicle serial number stamped into frame assembly near the cannister, you will find that your vehicle numbers all check out.
Get a rag & a little degreaser & wipe over that stamped number you will find you have nothing to worry about.
Your cars numbers certainly say LH SLR 4.2 V8. Have you some pictures you can show us?
Garry
Edited by SLR5000, 03 February 2006 - 10:28 AM.
#17 _Torana482HP_
Posted 03 February 2006 - 12:13 PM
so is the sable metallic a silver colour?
and the ash vinyl blue? and yes mine does have the cloth inserts.
ill go have another look at those numbers to double check, but ive had the paint over the chassis number sanded back and i was pretty sure that i was right on the numbers.
its funny cause the numbers are so close and similar (only 30 cars away) but ill go have another look and get back to ya.
Thanks for your help.
R Ant.
#18 _Torana482HP_
Posted 03 February 2006 - 12:23 PM
ill check out some places on the net where i can put me pictures up and post some pics of me car on the forum (ive been meaning to do this for a while).
#19 _Leakey_
Posted 03 February 2006 - 02:47 PM
All number checked out, especially 8VD77.
As a bonus, the under dash air conditioning I thought the car
had turns out to be 'dare I say it' factory plumbed through the
existing vents. The fan switch and sliders have additional settings, like
those shown on REDA9X's scans.
All original interior. Factory demister, both mirrors, factory electric arial.
Man am I stoked!!!
Thank you all for your help in verifying this is the real deal.
- I would probably have bought it anyway, even if it wasnt a real SS.
Cant wait to get her home to Sydney and get cracking.
Rust in C pillars is baaaaaad. But not unsavable!
Cheers, Leakey
Posted 03 February 2006 - 03:07 PM
