T5 into an LJ
_torana38_
, Feb 04 2006 01:14 PM
8 replies to this topic
#1 _torana38_
Posted 04 February 2006 - 01:14 PM
Has anyone had any experience with putting t5 gearboxes into LC or LJ. I am currently racing an Xu1 with 253 HP at the wheels and my advice is that a Supra will not be stong enough, but I dont want to hack the transmission tunnel around too much.
Posted 04 February 2006 - 11:25 PM
No idea but am doing the same conversion shortly (within 5 years the way things are going). All I can tell you is that gearshift is "close" to original location and the tail shaft spline is the same.
RACV MAN
RACV MAN
Posted 11 February 2006 - 08:17 PM
Toy gearbox, and will have to cut the tunnel. A surpa R154 will fit.
#4 _Bomber Watson_
Posted 12 February 2006 - 11:33 AM
are we talking a plastic comodore t5 (plastic cause they may as well be...) or a tremec t5????
Posted 12 February 2006 - 02:22 PM
yep at plastic comodore t5. They are the worst gearbox aroundare we talking a plastic comodore t5 (plastic cause they may as well be...) or a tremec t5????
Posted 12 February 2006 - 03:17 PM
Good enough for my application thank you gentle men.
RACV MAN
RACV MAN
Posted 13 February 2006 - 12:14 PM
Is it a t5 out of a vl, that puts the shifter in the right spot as I think the vn-vs t5 shifter sits further back which might interfere with the h/brake.Or do you just modify the shifter?
Posted 13 February 2006 - 10:56 PM
I measured mine from the bell housing back to the centre of the gearstick in neutral. VK T5 and the Aussie that I removed. They are both 24 inches give or take an inch.
RACV MAN
RACV MAN
#9 _lcgtr_
Posted 14 February 2006 - 04:21 AM
the VK and VL T5 gearboxes came in the HDT & HSV vehicles were T5Gs. The shifter is in a different spot from the VN variant
