thermo fan switches
#1 _high_rpm_
Posted 16 November 2005 - 09:34 PM
cheers,
high_rpm
Posted 16 November 2005 - 10:32 PM
#3 _high_rpm_
Posted 16 November 2005 - 11:26 PM
#4 _@milco@_
Posted 16 November 2005 - 11:41 PM
twin 10" fit perfectly on a lj radiator
#5 _JNR_ATE_
Posted 16 November 2005 - 11:56 PM
Self tapper the switch part to the rad support or so,
I think the brand was ICE and cost about $40
JNR_ATE
#6 _[BOTTLEDUP]_
Posted 17 November 2005 - 01:30 AM
#7 _Chaotic_
Posted 17 November 2005 - 08:31 AM
Posted 17 November 2005 - 12:47 PM
The VN on commo ones would not be any good as they are just a tamp sensor and it is the ECU which turns the fans on so you could use the VN temp probe but you have no way of telling the fans when to turn on and off.
You can use that style of sensor and make an electric circuit ( 2 comparitors driving a relay) to switch the fans on and off as required but a but of stuffing around.
Hi-rpm,
If there is a device off the shelf which does this all in 1 unit or kit, I would be interrested to know.
M@
#9 _Yella SLuR_
Posted 17 November 2005 - 02:18 PM
I've put it in now and no-leaks. Seams to all work pretty good.
Edited by Yella SLuR, 17 November 2005 - 02:19 PM.
Posted 17 November 2005 - 02:38 PM
Mines never had that Had to resort to using silastic around the copper and letting it set, then when the hose is bolted on it squashes down and works similar to the rubber, just takes a bit of farking about to get rightI got the thermo switch you are talking about. There is a little bit of rubber in the kit, looks like a double-sided door wedge with a groove in the middle. That takes the sensor wire as it comes out of the top radiator hose to give a perfect seal. I found out the hard way what it was for (read leaked like a sieve).
